Gzes
the drifting 2dr
Wichita tx
Put on a heavy duty radiator so hopefully it helps. Gonna do big 3/4 when I get a big crimped or a torch for sauter. Have 0 gauge so that should be enough for my high output alt
Y2KpewterZ
Got LEDs in the cluster and hvac. Next are the window switches and door locks.
95escahoe
Dropped it off to get the leafs/drop shackles/keys and some other things done
bigal11419
Queens, NY
Got her professionally detailed to get the last of the previous owners funk out of and off of it.
Finally she's clean :)
bowtiefreak
No Quarter
Near Philly
got the best alignment my tahoe has EVER seen. Guy did great work and came highly recommended. After hearing NO from three other places this was a relief. I think the suburban needs new shocks and a crank...then an alignment now
95escahoe
Got around to doing the leafs, drop shackles & keys, poly front and rear swaybar bushings, and new frame bumpers, could have went lower but good for where I live
omaha
Replaced the inside door handle on the driver side as well as the switch that controls the mirrors. DIDNT BREAK A SINGLE CLIP! As you all know thats damn near impossible haha.
---------- Post added at 09:20 PM ---------- Previous post was at 09:20 PM ----------
Why did they tell you no?
knucklebuster283
Bethpage Tn.
Today I removed all the left over wiring from PO stereo, pulled the spark plugs and cleaned them. #'s 2, 3, and 7, caked with a white crusty crap. # 2 so bad it wasn't firing. Possible head gaskets in the very near future. Will be doing a compression test this week. Ran like crap before, now pretty good.
nikoniko99
Portland, Oregon
i just got ***** for $165(wasn't sure if it was a deal)! front and rear diff oil change... i didn't have any clue about any of it! after the mechanic showed me what he did, lessoned learned... check with TYF community before anything else! looked easy enough for a newbie like myself to do, oh well.
landsoul
For giggles I went to the local Chevy dealer to get a price on replacing the upper and lower ball joints. They quoted me $1,400 for one wheel.
I laughed and did it myself for under $100 using Moog parts.
I ordered all my felpro gaskets, thermostat and bolts to get ready for this weekend when i replace the intake gasket.
noJeepshere
Bountyfull, Utahrd
I'm on vacation about 700 miles from home, and of course the water pump decides to puke coolant all over...
cent frum a smaert fone
landsoul
Met up with Justin from Black Bear for an upgraded performance tune. Really enjoying the responsiveness of the throttle and the shift points.
bigal11419
Queens, NY
Replaced the rear wiper arm due to the old one only clean half the window. Wound up having to cut the old one off, it would not budge.
99YukonSLT
Ohio
Oil change, rotation, and picked up some 17x8 American racing wheels on the Summit Racing discount rack today. One has a slight dent on the lip which I can get fixed through work or just live with it. Any tire suggestions?
Hodmjstone
