fredfifty
DC
SES light came on...made some adjustments...BAM, gone. (by adjustments I mean added oil and washer fluid lol) it worked! Now stay off SES light grr.
noJeepshere
Bountyfull, Utahrd
No doubt about that lol. Im sure ill learn one day... probably not though haha
---------- Post added at 03:54 PM ---------- Previous post was at 03:53 PM ----------
Also, im thinking about not putting the wiper and motor back on because it doesnt work for shit any ways and I think it gives the back a smoother look. Anybody ever done this? Any creative ways to cover the 2 holes in the glass?
In that case you probably shoulda ordered a new lift gate glass from LMC or kept an eye out for a factory glass without the wiper. As for covering the holes, I have no idea. But a factory wiper arm is only $45 from the dealer, because I bet the wiper works, but doesn't clean the glass. The hinge that allows you to pull the wiper away from the glass is probably all corroded up.
omaha
I didnt know they made them without the wiper motor. And yeah you hit it right on the money, it just does not press against the glass hard enough to do anything. Im going to go to the hardware store tomorrow and hopefully get lucky enough to find a hard plastic or rubber gromet/plug/cap thing that would work well.
noJeepshere
Bountyfull, Utahrd
Got the new rear axle for my Yukon. 14 bolt full float with factory discs and a gov-lock and 4.56 gears. Axle swap is getting closer B)
cent frum a smaert fone
jerryjoe28
That Guy
cabot AR
Had a wheel cylinder go out on me going down the interstate!.... replace both cylinders, installed new shoes and hardware on the back, flushed all the fluid. glad that is over!
Delvy
Installed Kenwood Garmin double din radio. Cut up dash and repainted it.
Delvy
Barely fit. Lol.
Delvy
Color matched front emblem and rims with duplicolor spray paint.
Delvy
Installed rollpan and got the top rear corners painted.
Gzes
the drifting 2dr
Wichita tx
I'd say so.. wellim puzzled... Out many new parts but the 2dr is still acting funny... Wants to overheat. Did water pump, thermostat, edelbrock Intake and gaskets, e fan. Yanked the e fans because didn't feel they were working enough to cool the beast. Still wants to get up in heat... Gonna put in a heavy duty radiator even tho this one never has let me down since I installed it a few years ago
tahoe.mkIII
mkIII- front door hinge pins & bushings, msd coil, ICM, plugs, wires, cap & rotor, k&n filter, new factory radio(w/ipod port), led's in the climate control panel, cd slave delete pocket.
limited- new gatorback belt(driving home 250 miles with a squeaky belt was unacceptable)
bigal11419
Queens, NY
Complete new exhaust installed. Flowtech shorty headers, Magnaflow direct fit cats and Magnaflow Force II direct fit cat back exhaust. Probably killed my fuel economy on the ride to work this morning I was enjoy the sound so much.
95escahoe
How did the Flowtech shortys fit?
---------- Post added at 08:33 PM ---------- Previous post was at 07:01 PM ----------
The leafs, u-bolts and saddles came in, waiting on the 2" drop shackles and keys
jerryjoe28
That Guy
cabot AR
[/COLOR]The leafs, u-bolts and saddles came in, waiting on the 2" drop shackles and keys
[/QUOTE]
nothing better than new parts!
wwiizz
