Just installed my helper bags! :D
BlizzardX23
Sacramento, California
Air Lift 1000 - Kit/Part Number 60769 (Thanks Max for the info!)
Took forever because the people who did the hackjob trying to cut one bump stop bracket off didnt seat my coil isolator...so I had to run to the store and rent some spring compressors to fix the isolator so there'd be no issues with the bags...anyways, after half a day, they are finally in! I know Max is running around 5 psi he said, but Im running at least 10 psi till I get new shocks..sad thing is, I still cant drive the truck till my new fender gets here!!! :(
Thats 1 out of 5 packages received this week...waiting on the others! :D
Travieso
Boooooooost !
Los Skandeles, CA
good to hear... Did you notice the ride quality dramatically change ? What other plans do you have for your truck ?
BlizzardX23
BlizzardX23
I havent been able to drive it yet since I have no fender/battery mount/fuse box mount...but Im sure its going to help TONS!!! :D
I have a few things Im doing this week as the parts start rollin in ;)
MASS-HOE'Z71
Mass
Nice, that sucks you can't enjoy it yet tho, I'd be goin crazy if I had a new truck toy installed that I couldn't play with yet.....how's the efans and custom cai projects comin along unless those are sum of the awaited parts
BlizzardX23
BlizzardX23
E-fans, Driver Front Fender, AEM Bypass Valve, and K&N Filter wraps will be here hopefully this week..cant wait
---------- Post added at 10:03 PM ---------- Previous post was at 09:40 PM ----------
---------- Post added at 10:07 PM ---------- Previous post was at 10:03 PM ----------
Can anyone spot my AirLift Valve Stem?
Just fill the bags the same way you fill your tires :) very easy!
Max
Mile High
Denver
I almost put mine there, ended up hiding it behind the hitch
BlizzardX23
BlizzardX23
I was going to do that...but some hoses are harder to get into spaces like that...so I made it somewhere easy to access..and I figure, the bags have to do with towing...so I placed it next to the other towing piece
NathanJax
Vacation Nathan
Jax, Fl
I still have yet to install the bags so mine rides like poop. But thanks for the pics (both of you) because it gives me ideas on where to put mine... If I'm not too lazy I'll get it done this weekend...
Max
Mile High
Denver
Pretty easy dude I can pm you some tips but it's fairly straightforward. Ride quality is dramatically improved.
BlizzardX23
BlizzardX23
After I blew my airbags, I had to crawl under and reinstall one...here ya go
I call him AB the AirBag
After jacking up the truck with those bricks..I saw the truck sliding forward...so I lowered it and rethought what I was going to do...last thing I wanted was to be under there and my hand get stuck between the spring while removing the bag..
goozdenali
Banned - Bad dealings with members
massachusetts
if i remember correctly he put too much air in it, he didnt realize how fast they air up.
quick66ss
Columbus Ohio
BlizzardX23
I was thinking of going this route as my Pedders kit leaves me little room for suspension travel. With 6 people and 2 dogs the thing was almost on the bump stops. I might swing by Jegs on the way home and pick up a kit.
Mike
NathanJax
Vacation Nathan
Jax, Fl
So wrong...
Did you ever figure out why it blew the one bag? I might have missed it and if I did I apologize. Percocet owns me tonight...
Yup
BlizzardX23
Mike
BEST MOD EVER
, I paid $75 for my kit. I think Bliz did too
JeffK
