WTF do i have to do to get this spare tire down!
BEEMDUB
PIMP DADDY FLEX
Michigan
So of course my stupid secondary latch is stuck or whatever I've done everything in the manual and I cannot get a pair of channel locks around the cylinder to release it is this ****** real life ? What more do I have to do to get this goddamn thing down I've been trying to for hours!!!!
---------- Post added at 01:18 PM ---------- Previous post was at 12:48 PM ----------
nvm sawzalled the hell out of it and got it down **** you gm
BEEMDUB
BEEMDUB
PIMP DADDY FLEX
Michigan
Did you try wd40?
Bro I couldn't even get the tire down far enough to SEE the mechanism at all
I could barely even squeeze a hand in between the top of the spare tire and the car to touch it with my finger and that was WITH the air let out of the tire--
Young28
The Yukon God
ga
i was going to say if you dont want to put it back up sawzall or cut off wheel.
fiatdale
Houstons Best
Houston
Yup. Have had to do this many a time. If you cant get it down, see if you can get it down far enough to take the 15mm bolt that holds the hoist up to the frame. Youll still need to cut the cable if you cant get it released though. Sometimes a lot of kicking while moving it up and down gets it released. But its very common for those bitches to get corroded and lock up. Every one of mine has always done that.
Good idea is to drop it every now and again and lube it up. Those hoists are expensive too, like $110.
BEEMDUB
BEEMDUB
PIMP DADDY FLEX
Michigan
Yeah I could care less about a spare tire if I get a flat im not changing the tire I'm calling AAA lol so I'm leaving it off
Clean07Burb
Once I finally got mine down by removing the one 15MM bolt that holds the whole spare tire winch assembly in place, I took a grinder to the secondary (safety) latch and lubed the remaining assembly. My spare tire now lowers up and down like a DREAM! Of course, my spare tire is now supported ONLY by the cable, so if it ever snaps while I'm driving down the road, I'm ******! Lol. I highly doubt that'll ever happen. It's like 1/8" steel cable holding that tire in place, which probably has a breaking strength of over a ton.
08grey
Lmao. Your not ****** the guy behind you is.
foxracer025
After reading this I'm going to make sure I can get my spare down this weekend and wd40 the hell out of it.
Gzes
the drifting 2dr
Wichita tx
I run no spares lol... On my other vehicles it has always worked fine. Dirt has gotten in them but after cleaning it worked fine
fiatdale
Houstons Best
Houston
Its a huge problem with any vehicle driven where there is salt. Almost every vehicle I owned from NY was that way.
CrashTestDummy
Pearland, Texas
Don't use WD40! It'll work in a pinch, but it gets corrosive in the long run, especially with moisture. Lube it up with something thicker, like chassis lube, or lithium grease.
latemate
It should be re greased once or twice a month just to avoid rust and lock up.
JasonW4141
