qukon 95
I changed the rear pass side cargo door hinges nice and solid now i'll tackle the driver side another day
95escahoe
Shackles and mounts came in, ordered poly rear sway bar and leaf spring bushings
omaha
Got my 3" body lift on last weekend. I need to take better pics, get WAY bigger tires, and crank my keys to level but this is what it looks like now
95escahoe
Poly leaf spring and rear swaybar bushings, new shackles and hangers going on Monday
95escahoe
Installed the shackles, hangers and poly swaybar bushings
Berserker
Az
Last night, Rebuilt the Throttle Body. Put in an adjustable fuel pressure regulator along with a new fitting to put a pressure gauge on, installed an injector spacer, all new gaskets and put in a throttle body spacer.
I wasn't sure it would boost the power all that much, but after getting it rebuilt with upgraded parts and getting the fuel pressure up to 14 PSI, holy crap what a difference. Seemed to start up faster this morning, idle is much smoother, and the pedal response is night and day better.
Now just need to drive it around for a few days and see what kind of gas mileage it is getting. Might experiment with the pressure to see what results I get. Very pleased with the outcome.
qukon 95
one H I D ballast went bad ordered another kit from ddm tuning once i get it ill send the bad
back for a replacement. it lasted sinse 2009 and there cheaper in cost now .
wwiizz
