Y2KpewterZ
Finally replaced the old crappy highway tires that were on the Yukon. Got these 31x10.5 for 730$ at Sams Club including installation! Got a pretty sweet deal considering how expensive the duratracs usually are. I've fallen in love with my Yukon all over again!
What do you guys think? Ditch the factory running boards or keep them? I don't really need them to get in and out since I'm fairly tall but I do find them convenient sometimes
Nice color combination :thumbsup:
But i like to running boards on mine. They sort of serve as a door mat lol
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I hope all is OK.
well learning to walk again. should be able to not use a walker soon. every time i get this sickness i need iv vancomycin. that with being in a hospital bed really kills my leg muscles quickly. so it takes about a week or two to get that muscle power back.
AlyssaB
Austin, TX
Thanks! I love yours, thanks for the picture! Now I can see it without them and I love it. I do like the function of the running boards unfortunately which is why I'm so torn on what to do with them.
Did you replace your "1500" door emblem with a Tahoe emblem or am I seeing things?? Ive been wanting to take the faded gmc1500 tags off my doors and put newer Yukon badges there but wasn't sure how they would look!!
Sending positive thoughts your way sunlit, feel better soon!
95escahoe
Put on the modded TBI unit, along with a TBI spacer and spliced in new injector wiring (had spots where wire was sticking out) ill post pics latter
Sunlit: hope you feel better soon
SunlitComet
OBS Jedi-Do Good
looking good. i see you have a bracket to mount and a convoluted tube with nothing in it.
---------- Post added at 05:17 PM ---------- Previous post was at 05:16 PM ----------
i take it the new manifold setup is creating the slack on the throttle cables?
95escahoe
Ya thats causing the slack, still shifts and drives great, is there a way to get the slack out?
SunlitComet
OBS Jedi-Do Good
look at it this way. have someone hold a wot(engine off of course) while it is being held grab the shaft and see if it will open more. if so find a way to tilt or move the shaft back while keeping the cables relatively straight going into the sheaths. just need to have some minor slack with out killing extra input from peddle. cruise cable not as important on slack for the most part.
95escahoe
That engine looks dope
Thanks
Sent you a pm about that
jerryjoe28
That Guy
cabot AR
replaced the fuel pressure regulator..... what a pain!
then I decided to run down and check out my duck blind to see what kind of maintenance would need to be done before the season gets here. on my way back I decided to take a "short cut" that you have to cross a small creek on. not sure what happened but I hit a decent size hole that has never been there in the past... much to my surprise some water splashed up on the intake and got the K&N filter wet :( . so it looks as I may have to be rethinking the cai
Chevrolado
Redondo Beach, California
Energy Suspension sway bar bushings
R1Concepts slotted rotors and PosiQuiet ceramic pads
And you could say my previous bushings were pretty shot... hah. No wonder the thing wobbled all over the place.
95escahoe
Looks great
SunlitComet
OBS Jedi-Do Good
missing the inner fender skirts?
jerryjoe28
That Guy
cabot AR
nah they are there and intact - looked like water came up by the headers on the pass side hit the under sided to the hood and then ran to the open air box... im not positive on that but I know the under side of the hood was wet and so was the K&N element
SunlitComet
OBS Jedi-Do Good
would not have hurt anything that small of amount. if anything it might have caused a temporary air cooling effect.
---------- Post added at 06:50 PM ---------- Previous post was at 06:49 PM ----------
keep the kit in there.
wwiizz
