Build Vs Buy (5.3 to 6.0)
Big Buttons
The SS Burb
South Texas
So you want 350-400 to the wheels? Get a used 6.0 from a yard, clean it up and put in a decent cam de-bur the heads, some LTs and boom 350-400.
I have the same set-up on my 5.3L and have 358 to the wheels.
You WILL need transmission work done. Either build the 4L60 or swap in a 4L80.
TxDrewski
TxDrewski
Potomac,MT
That may just be the ticket lol.... I was basically debating the pros/cons of a new 5.3 vs building a 6.0. At 460HP/460TQ for that price, and not having the issue of time invested in building a 6.0 I get from a yard or CL, seems to me that might just be the best all around blend of time/money/longevity/ease of install/etc etc etc...
---------- Post added at 10:00 PM ---------- Previous post was at 09:59 PM ----------
I mean the more I look at it.... That thing is just BAD lol.
---------- Post added at 10:02 PM ---------- Previous post was at 10:00 PM ----------
You WILL need transmission work done. Either build the 4L60 or swap in a 4L80.[/QUOTE]
With mine being the Z71, would I have to use a Specific Z71 4ll80 or could I just buy a used one from a low mileage truck?
mattluttrell
The cheapest route could be to trade it for an Escalade or Denali of equivalent year, rebuild the 6.0 with a cam, headers and tune it after break in.
You would get the transmission you need, the block you want and the torque we've all mentioned.
TxDrewski
TxDrewski
Potomac,MT
Thats a negative sir... I love my tahoe lol. I cannot stand the looks of the escalade or denali.
justinlw
Nearly everything is interchangeable with the later 6.0 including intake, harness, PCM, transmission, etc. you could take a 6.0 long block and swap everything from your 5.3 and be done after a custom tune. The trans may or may not hold up, if it goes then have it built for the extra power. If you decide to swap in the 4L80, I believe your driveshaft will work with swapping out the yoke only. I put a 4L80 in my '67 chevy with only a yoke change (removed a 700R4).
TxDrewski
TxDrewski
Potomac,MT
Usually I can spot 4l80s on CL within a couple hours of the house... Ill probably pick one up and take it to PATC in Shreveport. have the 6.0 and built tranny ready to go and pull out my 5.3 an 60E and do the swap, then build the 5.3 and 60E and have a good combo for something else or to sell to recoup the cost. Anyone on here own/know of a good shop to do the swap in the Tyler/Houston/Dallas/Shreveport area? all are within a couple hours of me.
justinlw
I know a few guys here in houston that do good work. What's your timeframe?
justinlw
I'll get in touch with a couple of people and see what their schedule is like. The one I have in mind has done a few truck/car Ls swaps. This isn't really a "conversion" since the new motor is just a drop in, so it shouldn't be hard to find someone to take it on. If you decide you want to do it yourself, I'd be glad to help out.
TxDrewski
TxDrewski
Potomac,MT
I may do it myself. I have all the tools minus an engine lift (Harbor freight is exactly 7.3 miles away), and Ive pulled engines before and swapped a transmission. however they were all on mustangs and one nissan. time will be the biggest factor for me since I have to have my hoe for work, but im looking at getting a 95 to 98 silverado or sierra too.
---------- Post added at 01:04 AM ---------- Previous post was at 01:03 AM ----------
Could not live in a dry county.
Lol its wet now so its all good. Just cant buy liquor.
Gzes
the drifting 2dr
Wichita tx
Hate dry counties. Imo I really would just build yours up. Or buy a junkyard engine build it then sell the one I. Yours. Cheap and reliable
---------- Post added at 12:08 AM ---------- Previous post was at 12:08 AM ----------
5.3 can take 1000hp on stock bottom end
livingez_123
Sandy, OR
Nothing wrong with a dry county, the whole damn world could be dry and I wouldn't care.
As for your engine, just do the swap yourself and learn a few things on the way.
FrankU
Babylon New York
Agree , I love my Tahoe, escalade or denali esp. the newer ones not so much. Go with that 6.0.
If my 5.3 didn't run so damn good that 6.0 would be in there now.
scoobyxj
School me a bit here... I thought the only difference in the (truck) 5.3/6.0 was the bore, and stroke (the block is actually the same), and the only difference in the 4L60/4l80 was internally the 80 is heavier duty, and had a slightly different ratio in each gear (again the cases being the same).
EDIT: I agree on the Denali, and Eskys. The Esky is to much of a status statement nor do I care for the interior, and I'm not a fan of the Denali exterior. To much extra plastic cladding, and I'm not much of a fan of the headlamps.
justinlw
I haven't worked on transmissions in a while professionally, but th 4l80 used to be longer/larger, and about 100lbs heavier assembled.
---------- Post added at 12:07 PM ---------- Previous post was at 12:03 PM ----------
Bob LaFord
