Passenger side cabin fuse? - Solved
genestoy
Arizona
Would appreciate some help locating a fuse in my 2026 AT4 either a Micro 3 or Micro 2 in the passenger side fuse block that will be activated with engine on and off when engine off. I will be using a Tap-A-Fuse. If anybody knows a fuse number let me know, it does not need to have a lot of amps ,maybe 5-10 amps?
Thanks for any help!
G
genestoy
Arizona
Found the answer elsewhere and for anybody looking for the answer in the future it is fuse #26 in the passenger side dash fuse box. And just in case this confuses you and shows constant power it will until the vehicle shuts down completely up to ten minutes. It is a Micro 3 fuse tap that is needed.
Thank you for posting and title tagging your solution to your issue with SOLVED. Our collective knowledge base has been increased.
CRN_25
