chaingun427
OBS Mad Scientist
Mooreland, OK
Use a can of starter fluid to check for leaking gaskets, ensure your injectors are seated and plugs are tight with no frayed wires. White running you can pull injector wires one at a time too, if the mirror doesn't change when you unplug an injector either you aren't getting fuel to that cylinder or your aren't getting spark there.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Gzes
the drifting 2dr
Wichita tx
I got it running but still not fixed. Pulled throttle body off again and put new gasket. Realized the hose that goes under throttlebody to throttlebody wasn't connected so connected it and adjusted throttle a tad bit and was running. Pulled it to road and stumbles bad from stop to 1esrt gear. Had to floor it gurl it stumbled and stumbled and stumbled and finally got a little power. And then drive and limp back home. Glad I was a street away otherwise id have to ditch it and walk home for my dolly
rmodel65
The iac is a common failure on the ranger I replaced one twice on my 98, pick up one from the junkyard cheap and see if it helps
a lot of times you can easily clean them
noJeepshere
Bountyfull, Utahrd
Went wheeling, got her muddy.
Partly because I got this in the mail from it:
cent frum a smaert fone
chaingun427
OBS Mad Scientist
Mooreland, OK
Good god that was the most touching thing I have ever seen a truck write brought a tear to my eye it did
Y2KpewterZ
Oh if only our trucks could talk or write letters to us...
Mine would say please fix this damn exhaust leak lol
SunlitComet
OBS Jedi-Do Good
unknown at this time.
BirchyBoy
BirchyBoy
My P0430 code came back. Guess it's time to replace the cat unit. Time to look for some posts from people that have done it.
SunlitComet
OBS Jedi-Do Good
have the wave forms of front and back sensors looked at first. if rear sensor level is low and flat then the sensor may be the issue. if it is active and looks like the same kind of activity as the front then the cat is likely the issue. and you can just bolt on new complete cat assemblies if you like.
95escahoe
Ended up finding these rims close by 20" Denali rims in gloss black he needed 5 lug got 6 by mistake, had them put on yesterday ill get better pics once it stops raining, debating about lowering it now
Sent from my HTC One X using Tapatalk
chaingun427
OBS Mad Scientist
Mooreland, OK
Those look good in black, all stealthy and junk lol.
I installed my bullbar, finally got it painted. I have a set of 100 watt driving lights to install on it soon to, kc clones with 6k h3 bulbs
95escahoe
Thanks, between the tires and rims only paid $800 lol
chaingun427
OBS Mad Scientist
Mooreland, OK
Not bad for a set of 20s, maybe with all the fender flares and such 20s don't look bad. But on mine they would have looked way too large
95escahoe
On Ebay there like $800 shipped this guy needed 5 lug not 6 so paid less then that and the tires got off CL for $250 only 5500 miles on them
Escalade2007
