body roll is crazy
swtz71
Mass
Hey Y'all I have an 04 hoe with a 2/3 Belltech drop w/keys, shocks are Dropshock 2's
Lately under hard acceleration the truck rocks back and forth hard core and doesn't stop till i let off, mostly getting on the highway. serious safety issue i think.
I'm thinking my shocks have bit the big one and are causing it to rock but maybe I need to do something else to the suspension to stiffen it up so it performs like it should.
Any suggestions or tips would be awesome!
thanks in advance..
NathanJax
Vacation Nathan
Jax, Fl
shocks and sway bars
yates ™
Resident Apple hater
Iowa
If it started all of the sudden have you checked the sway bar bushings?
swtz71
swtz71
Mass
I thought the same thing but i was under there the other day and everything is in tact
---------- Post added at 01:39 PM ---------- Previous post was at 01:37 PM ----------
Here's my old Esky and it's suspension setup. It drove like it was on rails...
suspension mods are listed including sway bars and shocks
http://www.tahoeyukonforum.com/forum/showthread.php?t=5284
sweet!!
well I might as well upgrade my swaybar and shocks it is a good start
ccapehartusarmyINF.(ret)
Gilbert AZ
your shocks are bad when i bought my tahoe it rode like yer grandfathers 84 cadilac it bounced and rolled all over the place once i replaced the shocks problem solve4d
WHITEOUT
Dont Hate-Appreciate
Phoenix
DJM Shocks?. My BT SP are going bad, and starting to get same thing. Boat sway, but over dips is my main problem. Espexially on freeway
04blackout
I've got the same issue, with the same shocks... trying to decide between qa1 or ridetech adjustables
Z-56 Hoe
What do I do????
Houston
Bilstines 5100's. Lose the T bar drop and get the 2" drop knuckles / spindles, Also do the sway bars, I had the same drop as you and same shocks and that is what I did I also added ready lift helper bags to rear springs. Of. They make a drop bracket for the Nivo max shocks Mine rod like a dream with those for years till they died. I've had my 01 for going on 14 years now.
swtz71
swtz71
Mass
So 2" spindle drop. How much is that??
Z-56 Hoe
What do I do????
Houston
Cost me dam it's been a while. I think $500 but it may have been more I had other work and new 4.10's and a eaton. Done all at the same time.
CKendrick
