Chevrolado
Redondo Beach, California
Straight axle swap
Sent from my HTC6435LVW using Tapatalk 2
So I didnt read anything above this post yet today.. but I came in to read whatever the last post was. I saw this. I then promptly said to myself... "Wait... What did you do to your OBS GMT400 TODAY? Straight Axle swap?? In one day?! Wow.."
Then I read the rest and realized you were just clarifying. hah. And here I thought you were doing work of epic proportions today Don. :laughing1:
Gzes
the drifting 2dr
Wichita tx
Think I blew my 8th wheel bearing today lol I really need to SAS
X2 but no broken parts just hate ifs and can't find dana 60s here... might have to settle with a crappy dana 44... really want king pin and will do high steer eitherway. Don its probably easy for yoy to find the parts and it shouldn't be hard just time consuming
---------- Post added at 10:11 PM ---------- Previous post was at 10:07 PM ----------
Sas could be done in a day if yoy have proper tools and no setbacks which is never the case. I plan to take my time and do it in a week if everything goes to plan and have all proper tools
---------- Post added at 10:12 PM ---------- Previous post was at 10:11 PM ----------
O and don its solid axle swap not straight axle swap noob
95escahoe
Washed it and installed the led reverse bulbs
Sent from my HTC One X using Tapatalk 2
qukon 95
i changed the bottom driver leather seat to one in way better shape than mine and stuffed some foam down the
sides of my escalade center console it was rattling with the bose sub thumping.
qukon 95
Got new 265/75/16 cooper ht tires on my chevy 2001-2004 wheels
i got for free my gmc stock wheels looks really bad.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Went out to it yesterday and found two flat left tires. Apparently happened Sunday according to a neighbor the he saw them low early evening. Had roadside come by and put some air in them. They held it so I drove a mile to a used tire shop to get them replaced with other used. Just in case being as how they appear to have physical damage to them in the form or small cuts or minor tread damage on the out edge.
Got the second engine replacement pulley in the mail for the belt tensioner as well as the brake pedal switch.
Knees still in to bad of shape to get out there and get some work done on it so I will try again sunday to get that stuff and headers/cats done. Think I have the flu or something. Achy joints, sneezing, sniffles and stuff.
newbie78
Put in a new FPR today and got rid of all my codes p0172, p0175 and p0300 :favorites37:
As you can see in the pic right below the FPR the manifold is spotless clean and everywhere else is dirty. Definitely the FPR is bad when you see it that clean below it.
but... now I think i have a small vacuum leak. I hear a whistle/whine sound that gets real loud but stops when i hit the throttle and comes back when i let off it.
So i gotta recheck things tomorrow. I hope I didn't crack the plenum because I couldnt press it over the fuel spider because of the new gasket. So I put 2 bolts in the plenum and tightened them slowly to press down on the gasket ?I heard a noise but I'm pretty sure it was the gasket squeezing.
Gonna spray carb cleaner around the plenum and other areas and see what happens.
It starts up no problem and no more odor or check engine lights and drives very good!:peace:
TahoeLimited
Fountain, CO
Filled the tank for the 2nd time since buying it, allowing me to calculate the MPG. Got 15.11 mpg, which was probably about 60-70% "city" driving (i.e., local, non-freeway runs). I'm pretty happy with that. I'm betting I could get a full 18 mpg if it was all freeway driving.
qukon 95
I found a way to cover the Chevy bowtie on my 2001-04 OEM wheels now I need to find some wheel
Locks.
newbie78
I changed the oil today. As you can see from the pic it was nasty! This is only 1 month+ old oil with less then 500 miles on it but it's contaminated with fuel from the leaking fuel pressure regulator I replaced yesterday.
Put in fresh Pennzoil and a new Acdelco PF52 not the PF52 E shit they make now. I ordered the original from RockAuto.
And found out that loud whistle/whine was my ac compressor clutch. I turned the clutch slightly and the noise is gone. They build up a slight amount of rust between the clutch and the pulley.
newbie78
Yikes! Good job for getting on it and fixing the prob quickly, and changing the oil...not just r&r'ing the FPR.
Yeah this is my daily driver and only vehicle so I want to take care of it. I'm meticulous with taking care of vehicles i own. I let that oil drain down to the very last drop went inside and waited over a half hour. I might drop the oil pan next spring and give it a real good cleaning.
TahoeLimited
Fountain, CO
...I let that oil drain down to the very last drop went inside and waited over a half hour. .
Alright...I do the same! And I try to jack it (or have it drain de-jacked) so the drain hole is angled so it's at the lowest point of pan. I always drain the oil hot so it's thinner and drains quicker. Also mixes up and re-suspends into the oil any sediment that might otherwise settle and sit on the bottom of the oil pan. Gotta get that crappy oil outta there!
qukon 95
put my new 04 chevy wheels with the new tires on tonight
and then shined them up:biggun:
SunlitComet
OBS Jedi-Do Good
Damn I would have chucked that old system for the upgraded on.
retorq
Kingman AZ
When I change my oil I take the engine out of the truck, pull it all apart, wash everything with a stiff brush and detergent, wipe it all down with a lint free cloth, put it back together and put it back in the truck.
:challenge:
_Dylan_
STAY FROSTY
:challenge:
Pfft. I just drop in a new crate motor every 3000 miles.
Hodmjstone
