Monstar_est87
City of Angeles
Read the update I added... Im still tryna figure out the a/c issue... The issue is that the a/c wont blow cold unless ur running at operating temps or ur constantly driving over 40mph... I think I got it figured out just not perfected yet...
_Dylan_
STAY FROSTY
condenser maybe?
Monstar_est87
City of Angeles
No its the fan setup... Its setup to turn on once it gets above operating temp-195°... I have my low speed turning on at 210°... I did tap the high speen to the Accumulator but the fan was running non-stop even with the key out :shrug: ... So I left it disconnected... And I got used to it... I plan on putting a front mounted push fan from a 2500, 3500 for the a/c...
noJeepshere
Bountyfull, Utahrd
I have the same issue, the a/c doesn't really work at slow speeds, any time. Only when I get above 40 mph does the air finally get cold. I don't ever notice the fans coming on at any time, even when I slow down. The rest of the system checks out so I think it may be the fans.
_Dylan_
STAY FROSTY
a bolt on pusher fan from a 3500 should make a big difference.
_Dylan_
STAY FROSTY
found a nissan wheel to match the rest, so I finally have a spare that is the same size...but I had to remove the rear sway bar for the spare to fit.
BillBlatt18
Latham, NY
Got my new corsa look alike tips welded on finally
Sent from my Galaxy S4 using Tapatalk 2
rolfsent
Cincinnati
That's robbery in the first degree great score bro get it installed quick!
Haha thanks. It's in the garage all taken apart to get ready to be painted gray. I also picked up a fog light switch for $5.
Drewphil
