Want a cam with a good amount of torque
lsu_beaux
I've read A LOT of threads on cams from multiple websites and haven't exactly found what I'm looking for. I would like a cam with more bottom end without losing any top end. It's a daily driver. Mostly city, until winter rolls around. Then I'm hauling Rangers and Four-Wheelers back and forth to the camp. CompCams recommended the 208/212 on 114 LSA, but I would like a 112. Anyone running this cam and like the torque gains? Anyone have any other recommendations? Mods are in sig.
Also adding LTs and ORY-pipe.
lsu_beaux
lsu_beaux
Could i run my stock stall with this or should i upgrade?
Travieso
Boooooooost !
Los Skandeles, CA
it ran with my stock converter with no problems, i did have my tuner flash tune my stall to about 1900 RPM
Here is the Description on there site
"THE TRUCKER"
STREET / STRIP / POWER
POWER RANGE 2000 TO 6200
TUNING REQUIRED
POWERFUL CHOPPY IDLE
DYNAMITE WITH A SUPERCHARGER
MOST POPULAR TRUCK CAM EVER BUILT
Stein2088
Butler, PA
Im very happy with my Vinci Trucker Cam, produce good amount of torque/horsepower through the RPM Rev band..
Did you notice any differance in fuel economy... I wouldnt mind more power but I dont want to sacrifice fuel economy
Travieso
Boooooooost !
Los Skandeles, CA
TO be honest with you it wouldn't be fair for me to try to compare fuel economy because i put the CAM and Supercharger at the same time and i couldn't keep my Lead foot off the Gas pedal
Stein2088
Butler, PA
Much appreciated... I look forward to hearing about your 4L80 install!!!
Big Buttons
The SS Burb
South Texas
[yt]3Rhmntl0Lrc[/yt]
Exact cam I have in my suburban. If you're pushing a lot of weight this is the cam comp cams recomended for me. My burb moves now.
http://www.speedengineeringlsx.com/comp-lsr-cam-219-227-607-614-112-lsa-54-456-11
This is where i got it from.
You will need to change springs with any cam basically. For this cam you need dual springs. Im running the prc duals. And while your in there get hardend push rods 7.4". Also can get lifters since the ones that come stock are noisy.
I can make an exhaust clip of mine if you like to see how it sounds in a 5.3
Donkey Punch
Panantukan
I'd like to hear it if don't mind posting it
skaffy03
West Des Moines, IA
How about this cam?
http://www.speedengineeringlsx.com/comp-lsr-cam-215-223-604-610-112-lsa-54-455-11
I've been in the market for a good torque style cam as well. I feel the lift is a bit excessive on the 215/223 LSr
But my eye is also on the 212/218 or the 216/220.
Big Buttons
The SS Burb
South Texas
Honestly the best thing to do is go to comp cams website and fill out the info sheet and a tech will get back to you on what cam you should go with. I followed their advise and never looked back and don't regret it what-so-ever.
Imma try to get that exhaust clip for you guys this weekend.
ASG-MikeS
