Monstar_est87
City of Angeles
It processes faster then the black box and is capable of more tuning things... Like wat im not sure..? I havent gotten in2 the specifics of that but its a better pcm for ur truck... Think of it like ur truck came stock with an iphone and u upgrade to anything else basically...
Tricky
Illinois
good luck with that. You can't hide anything in the yards around here. :lol:
I know, but I didn't think the first 120 speedometer would be there weeks later let alone another also, that's why I didn't think to bring $$, cause I was just browsing, getting fuses and and bulbs.
Sent from a Phone Booth using Tapatalk
slipping
Rosamond, CA
http://www.gmtruckcentral.com/articles/12200411.html
and to give you an ideal on its capabilities, if you were to change some hardware components and pcm with the right tune on that can do COP for a vortec 350.
Thats a good read. I'll sit down at work and go through it.
Got some goods in
McFizzl
Broke as a Joke.
Fayetteville, AR
Came out to a truck that wouldn't start. Found out the old distributor cap was causing the cylinders to misfire on opposite side. Luckily I didn't damage the crank. New dist. cap and rotor installed and she's running like a champ!!!
qukon 95
i have a antifreeze leak and found that i need a water pump went
and got one i painted it red. i got it at autozone the old one has been on there sinse 06 and it's a L T R one weather is cold right now.
95escahoe
pcm 0411 essentially complete. one ground wire circuit to build and harness clean up. took pics of plastidipped grill.
Came out nice, love the blacked out look
Sent from my HTC One X using Tapatalk 2
qukon 95
yeah!! the weep hole was weeping and put a new lower rad hose
and heater hose threaded fitting on the water pump. i guess the
gaskets are good. but i do have oil coming from under 2 bolts
i will take care of it later.
rolfsent
Cincinnati
Got to play in the snow. Also this came this morning from rock auto.
qukon 95
got my rear driver side barn door to open easyer added washers
to the bottom rod now i can open it with one hand.
_Dylan_
STAY FROSTY
JY run today
120mph cluster
5 cargo switches
denali fog light pigtail (far left) -for sale
McFizzl
Broke as a Joke.
Fayetteville, AR
Did a little detailing and got the paint off the back door panel. Looks like a kid smeared white paint on the door. Came off with some elbow grease and some armorall
---------- Post added at 05:48 PM ---------- Previous post was at 05:46 PM ----------
On mine all I have to do is push in and pull and the door comes right open. I wish I could just pull the handle but the bumper is tweaked so the door closes tight against it.
95escahoe
Installed the modded tbi unit today (ultimate tbi mods, 1/4 pod spacer, flow matched and cleaned GM injectors, rebuilt the tbi unit) runs a lot better got rid of the annoying shake at idle too
Drewphil
