Hands down best riding set up 07+ Autoride
NORCAL SS
SUV SUSPENSION GURU
Just swapped to the new version belltech tb springs in back of my escalade and I can honestly say im done with my suspension set up for it. Rides great!!!! I've been thru pedders/mcgaughys/belltech/eibach pretty much on my truck and now i found the perfect combo and I'm finished finally.
My set up includes
Front belltech spindles
Front Norcal SS modded struts (helps ride due to autoride link movement)
Front/rear DJM swaybars
Rear Norcal SS modded DJM hardware kit
Rear Belltech tb coils (new version)
Rear Spohn Panhard bar
rear spohn lower control arms
Only thing I will be adding is helper bags for towing (autoride still lifts truck up perfectly)
Just wanted to put the info out there and I'm just glad I finally got the truck dialed in and finished!!
WingsAA
CMFIC
Dallas, TX
Just swapped to the new version DJM springs in back of my escalade...
My set up includes
Can you elaborate more on the above? You've peaked my curiosity. :hands:
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
i modified the rear endlinks and replaced the 5305 with the belltech tb coils
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
How much for this package setup?
ill just not include my modded struts
1345 shipped
---------- Post added at 08:27 AM ---------- Previous post was at 08:26 AM ----------
So what is the final drop numbers front and rear?
Is this a 2/4?
305 35 24
front 34 1/8
rear 34 3/4
---------- Post added at 09:20 AM ---------- Previous post was at 08:27 AM ----------
btw if you guys are on a budget you can do the kit minus the endlinks and rear lower control arms. the swaybars help these trucks nicely. The 5305 coils do ride great i just like these a little better
Max
Mile High
Denver
Damn how many times are they gonna revise these things?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
ive been happy wiht hte 2/3-4 kit for autoride i just like this one just a little better, only thing cant tow as much need to get helper bags
my son likes it :)
Blazed
Accepting Donations
How did you make it this low with no alignment kit?
NathanJax
Vacation Nathan
Jax, Fl
Up front he's about 2 5/8
2" Belltech spindles don't do anything to the alignment and the other .5 to .75 will just max out your factory camber specs.
Blazed
Accepting Donations
Oh ok thanks!
I just threw the alignment kit on my Tahoe with the 2 inch drop struts.
NathanJax
Vacation Nathan
Jax, Fl
Oh ok thanks!
Yeah when i did the spindles i was good, but once I did the struts and went down anther 1.2 inches, I had to do the alignment kit as well.
Blazed
Accepting Donations
I effectively ruined my tires running all summer with a extremely ****** alignment and now $300 later I have the alignment kit installed and that was last Wednesday and I'm getting the final alignment tomorrow now that my tires are toast it won't do any good.
How ever after installing the alignment kit even without the actual aligning I did notice it no longer felt like an earthquake after the front end hit each bump and for that I was very grateful.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
at my level your fine. that 3 inch or more level is where you run into issues. All i know my strut mod works perfect on these trucks
Drewphil
