Belltech 2/4 with cornering ride quality...
What's the best rear coil?
  • Total voters
    13
NORCAL SS
SUV SUSPENSION GURU
they are progressive springs been the same since 2000 when they released the original 5305 coils. I have my brackets cut and my truck towing my ctsv in rear no issues with rubbing ac lines.
also when you cut the bracket off the frame you can always get longer bumpstops and cut accordingly to get the most travel without hitting any lines.
i have guys on 305 35 24 and 3/5.5 with bumpstop brackets cut no issues at all.
Blazed
Blazed
Accepting Donations
I know this makes me sound like an idiot but I had to drive about 45 minutes last night and idk half way home something changed and it rides alot better now Im quite pleased I really dont know what happened maybe my springs were not seated properly like you guys thought....
anyways now that this happened im going to stay away from the free travel mod
and to norcal thanks for always answering my emails quickly it helped alot through out the whole process
---------- Post added at 12:20 PM ---------- Previous post was at 12:19 PM ----------
no all i have left to do in front sway bar and end links and trailarm relocation
Goodinblack
I Like Tacos
Dirty South
Well good. Hacking away if avoidable is healthier. Please follow up with the sway bar update. Hey are you using the RK2007 kit from DJM for that?
Blazed
Blazed
Accepting Donations
I will as soon as I get a free day. I put on the rear sway bar when I lowered it originally just because it was lying there while I was under the car so I went ahead and did it but I still have the original end links which i know at this height the sway bar is almost useless but as far as I can tell the rear of my car is solidly on the ground I think once im completely done I will be extremely happy with this kit after all!
NORCAL, at 2/3 what do you think about the trailing arm relocation? is it still beneficial?
fire730
Louisiana
I had to get it on my 04 cause the driveshaft was slamming ino the transmission on larger bumps. That was only a 3" drop.
I haven't installed the drop kit yet on my 07 but I have the trailing arm relocation kit waiting to go on at the same time.
Most people don't use it on a 3" drop but I like the fact that it get the rear axle back where it was before the drop and puts less stress on ujoints and other suspension components.
Goodinblack
I Like Tacos
Dirty South
@FlyTahoeGuy........Thread Hijack...What tail lights are you running. I saw LEDS in you album.
Lee.
Blazed
Blazed
Accepting Donations
I got them from carid just to help you find them.
They are the CG LED red/clear
That's all I know that's why I said where I got them.
Blazed
Blazed
Accepting Donations
Thanks I guess I'll put it on
Blazed
Blazed
Accepting Donations
Ok i know this thread died but like i said Ive become really happy with the kit although I will be adding helper bags because I rode in my car five deep yesterday and bottomed out like crazy however when its just me or just me and a buddy i never bottom out anymore... just gonna do helper bags for the heavy days!
Alex33
I'm glad you got it sorted out and you're happy with the results.
Blazed
Blazed
Accepting Donations
yea thanks to all you guys for the quick replys those first few days really appreciated it
Modded
That Guy
First off,
I have had a couple of different drop coils and even though the Belltech 5305 coil rides good, the Pedders rode way better. The Pedders was only a 3" drop though.
Goodinblack
I Like Tacos
Dirty South
@ Modded, did the Pedders coil handle loads better? Meaning did it too bottom out as easily?
@ Blazed..... I am glad you followed up and did NOT let this thread die yet. Have you done the RK2007 kit for the trailing arms and sway bar yet.....any follow ups feedback?
I am running Airlift1000's on a 2 inch drop. They work, but I wished I had gotten a slightly bigger bag for a little more lift. Right now at 35# I only get about a 1/2 inch lift or so.
It does however prevent major sag. Empty it rides a little stiff too. I think when someone goes with dropping their truck they have to start "anticipating" loads. If you are caught off guard and have no air
in the bags you will rub/bottom out. I am still debating if I want to buy a compressor to air up on the go.
Blazed
Blazed
Accepting Donations
No I haven't got around to it. In Texas it's been like 100+ for a week!
Modded
That Guy
Oh yeah the Pedders coils handled loads a good amount better too. When I was dropped on those I literally could not tell I was dropped at all from the way they rode. I don't think I ever bottomed out on them.
The front Pedders coils rode good for two months and then the ride went to absolute ish because it needed a shock swap.
I also have the DJM RK2007 kit. It did not make even the slightest difference in ride but I figured I should leave it on there since it has little resale value.
Blazed
Blazed
Accepting Donations
Wait modded do you have the djm sway bars as well?
Modded
That Guy
No, I don't have DJM sways. Just the end link and trailing arm relocators.
Durobans
