3/5 Drop With Pics, DJM Arms, BT 5305 Springs
2005SnowKon
Fort Collins, CO
I just ordered 3 inch springs for the rear.. What should the ideal height be all around you think after I adjust everything
Alex33
I was at 32.5" F/34" R w/ a 275/45/20 tire. Most guys are around 33"F/34"R when all is said and done on a 2/3-4 and OE size tires.
Alex33
You "might" sit up a little higher, my concern would be rubbing on big dips. I think my wheels are a +30mm offset but you might be able to get away with your offset.
2005SnowKon
Fort Collins, CO
i guess ill find out in an hr or so when i go snag them and install them. I guess if it doesnt work the way i want it to ill get the kit the Norcal sells... His 3/5 kit
M Hankel
M Hankel
Vancouver, WA
beautiful drop...just doesn't look very comfy ride wise
Actually the ride is very good considering. If it had better shocks on the back it would ride just like stock. Right now the Belltech Nitro shocks on the back are just not doing well. I only notice it over broken pavement when it rattles the crap out of everything lol...
Mike
---------- Post added at 11:40 AM ---------- Previous post was at 11:33 AM ----------
looks sweet!
Thanks man!
---------- Post added at 11:43 AM ---------- Previous post was at 11:40 AM ----------
Do eet!!
Bilstein P/N - 24-143806 = Lots of win
Looks like a decent option at 69.99/each. I might consider an adjustable shock too, like a Rancho maybe? Would love the ability to dial in the ride. I've heard of guys running adjustable QA1's front/rear, but those are fairly high dollar for a daily driver IMO.
Mike
Alex33
I'm running the Bilsteins I recommended for your on my truck and I love them. I really looked at some King shocks but those were also pretty pricey for a DD.
HK-DEMON-
Stockton CA
I hope I'm not intruding in this thread by asking this question, but compared to the Street Performance Shocks would you say the Bilsteins are much better?
Can you provide a part number?
Alex33
Junior209
Do u have to remove the torsion bars to install the lower control arms
mykon04
Porter, Texas
M Hankel,
Hey what size tires are you running on your 22's I really like the way it sits. I have been on the fence as to wether just leave it alone or lower it. I am on the market for some 22's since I need new tires anyways. :)
M Hankel
M Hankel
Vancouver, WA
M Hankel,
I've got 305/40/22 on the front and 305/45/22 on the back.
Mike
mykon04
Porter, Texas
Thanks mike,
I was checking out your ride again today and I am going to go ahead and pull the trigger thanks for the info. do you have any issues with your tires rubbing or coming close?:Handshake:
M Hankel
M Hankel
Vancouver, WA
Thanks mike,
The fronts dont rub much except on tight turns. The back 45 series rubbed a bit on the plastic liner. I used a pneaumatic air saw to cut out the areas it rubbed and its all quiet now. Could easily drop another inch without rubbing. I have about 5 speed jumps leaving the subdivision I live in and they dont rub on those at 15 mph.
Mike
JasonW4141
