Another Customers 2/3-4 Belltech Kit.
Cocotits
Bay Area CA
I have shock extenders that came with my djm 5" blue springs. Are they going to work with this kit? I need to buy ASAP.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
the kit comes with new shock extenders which you can probsell.
Cocotits
Bay Area CA
Ight tony. I apologize for the confusion. But u just said the shock extenders didn't come with the kit ? N now they do? I got the link n went to it. That's the one I need?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
confusing me what kit are you talking about my djm kit or this belltech kit? if its this belltech kit all rear includes is spacers/springs/shock extenders.
Cocotits
Bay Area CA
I bought those new redesigned trailblazer beltech spring from u with my buddy. I'm tryin to put em on n take off the horrible 5"blue djms. I need the rear hardware kit for the truck. N then I'm installing the springs with the helper bags. Just havin trouble figuring out which kit I need cuz dang people telling me I need the offset sway bar struts, n in the pic they don't look like they are offset. And also they said the 06 don't come with shock extenders n it the same price as the 07 kit. There's my confusion. They are like just buy the 07 kit. " comes with more same price."
Plus my buddy bought different kits n not from u. N he had two diff kits with shock extenders. One worked n one wouldn't match up with the trailing arm relocation brackets. Hense my issue with wanting to make sure if the kit does not come with shock extenders are mine gunna work or am I shit out of luck? Lol I think that's my story now! Lmao
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
that is correct djm just did it like that where the 07 up includes the shock extenders. Dont ask me why but they did it like that.
the 00-06 kit does not come with shock extenders and on the 07 ups i usually just do the hardware relocation kit with a shorter shock and tell the customer to just sell the shock extenders but on the 07 ups the shock extenders do work with the djm trailing arm relocators.
and dont worry the endlinks are at a angle on the kit
Cocotits
Bay Area CA
Right on bro. Thanks for clearing that one up lol. I'll go ahead n purchase the 00-06 rear hardware kit that u gave me the link to earlier. The number Djm rk2000
Thanks again tony
Vinniety
Westchester, New York
That truck looks sweet. Tony - You actually helped me with an issue i had a few months back and thank you for that. I have another question and would like to know if you can help out............The issue is that i have the belltech spindles in front and in the rear I have the springs that came with the DJM 2/3 kit. I get alot of bounce int he back. Can that be becasue of the springs or maybe just adding a sway bar kit will help. I have bilsteins in the rear with shock extenders.
Thanks
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
djms with bilsteins ride ruff. I would look into gettin rid of the rear springs
drkhrse00
Dallas Texas
Thanks for all the feedback! Tony hooked it up. The kit has been great and put new life into my Yukon! Makes it alot more fun to drive! I have some more pics posted so you can see the gaps a little better. I have had some settling since i took that pic and the rear sits about 3mm lower. Im doing the camber kit and free travel mod this weekend and will update. gonna bring the front down another 5mm. Also those wheels are ten years old. I got em maybe nine years ago from tire rack as a close out. I had a buddy resurface them two years ago on his cnc machine.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
you got it man!! thanks again
drkhrse00
Dallas Texas
I did the free travel mod today. Made my own bumpstops. Also started to install my camber kit and realized the kid who did my alignment is an idiot.I had plenty of adjustment left even with a three inch plus drop in the front. The rear end came down about 5mm and i got another 8mm out of the front. Real nice stance. Front is lower than the back,now! I will post some more pics when work permits! Doing and alignment tomorrow,myself!
rollin23s
Austin, TX
Truck looks good, I am thinking about doing a 3/4 with 24s or 26s. Really am up in the air, nice stuff.
ludvball
I am installing this kit this weekend on my stock 03 Denali XL. I am also going from autoride to Belltech shocks. I know I need to take out the RTD fuse to disable autoride. Do I need to worry about any of the leveler sensors, or ay other components that are normally associated with the autoride system?
Also, if I want the rear drop at 3", I should install the spacer, but if I want it at 4", I should not install the spacer? If i don't adjust the keys up front and don't install the spacer, that should level her out?
Tony, thanks for the shocks. I will post pics when done. I got a feeling that I will be looking for wheels this summer (those are still stock).
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
if your only doing the rear you will need another spacer with 3 inch level will sit lower in rear than front. adding another spacer (ie 1 inch top and bottom) will bring it to about level
Drewphil
