Best/Cheapest tires on market?
THE YETI
Director of Operations
South FL
Kumho
You are crazy running a 305 that low. Go 295/35/24, you'll be happier. :)
Fearz
Houston
What's wrong with a 305? I thought that is what most people run.
OnE_bAd_HoE
OnE_bAd_HoE
Senior Member
Miami,Fl
Hes Saying that because i have a 3/5 drop and I rub like a mofo with 305, with the 295 i wont have much of a rubbing problem due to the tire being more narrow
ntxstallion
I think Kumho is a good tire. Have had nothing but good luck with them.
Fearz
Houston
Oh. Thanks for clearing that up. I have to check back to see how that works out cause that 3/5 is a very nice drop. Oh btw do you mind if I ask how long those 305 tires last?
soulsea
Administrator
Bar
Mmm, I rubbed quite a bit with 295/35/24s on a 2-3/4 drop.
If you're gonna trim anyway, might as well go with the 305s. :)
---------- Post added at 11:15 PM ---------- Previous post was at 11:13 PM ----------
Oh and to answer the question ... since you don't get much winter weather in Huston, the best value tire, which also happens to look awesome, is by far the Nitto 420s.
OnE_bAd_HoE
OnE_bAd_HoE
Senior Member
Miami,Fl
what do you gys think about Nexen??
im kinda on a budget right now so avarage tires will do but next round Im getting the Nitto 420 or BF Goodrich G force.
soulsea
Administrator
Bar
Others might know more about Nexen.
There is a theory however that the one place one should not cheap up on is tires as they are the only thing between your vehicle and the road, even if it means putting off other mods ... I for one subscribe to that theory. :)
THE YETI
South FL
Keep in mind that he and I had the same exact asanti wheels, offsets and backspace were identical. Your wheels were different, so I can only speak for what worked for this specific setup. :)
Chuckchill
