Opinions on Potential Hybrid Mods ...
^^^thats correct which is what I was trying express in my post but you worded it much better :D
Green Machine
Orange County, CA
i should have stated K&N "styled" filters.... I believe Green Air Filters/Intakes are oil-free/oil less
Ah, that's what I thought.
Are the other ones reusable like K&N's?
---------- Post added at 11:53 AM ---------- Previous post was at 11:50 AM ----------
Well, these just got here:
picture.php
We'll see what they look like before y'all spend more of my money. :)
soulsea, I assume these steps are heavier than the stock plastic ones?
Indeed ... looks literally outweigh mpg in my priority set. :)
x2...I'm sure the weight gain and MPG loss is close to negligible anyway :shrug:
THE YETI
Director of Operations
South FL
soulsea
soulsea
Bar
Does anyone know the part number/s for the LTZ specific side door moldings ... like this one:
picture.php
soulsea
soulsea
Bar
Ok so I got myself a set of oem LTZ side moldings, the plastic elements of which come primed ... the GM body shop wants to charge me stupid money to paint them.
Is there an easy way to match my paint and do it myself?
The black paint would be easy enough to match but going into a local auto parts store that sells paint (O'Reillys does this) with your paint code and they could get you some that you could spray on. The question is would it be the quality you'd want? I'd got to a local body shop in your area to do it. Realistically, the job shouldn't cost you more than $100 or $150 I don't think.
soulsea
soulsea
Bar
Mmm ... the chevy body shop quoted me $400 to paint to match, remove old moldings, clean off the adhesive, and install the new moldings.
Considering that other than the painting, removing the old moldings takes a simple heat gun and fishing line, and the new molding is pre taped, it seems to me $400 is too much no?
Or am I missing something? :think:
Yes....$400 is way too much. I'd have a professional do the painting and you can do the unistall of the old stuff and reinstall of the new stuff yourself man. It's extremely easy and pretty hard to mess up.
soulsea
soulsea
Bar
Yeah I am considering doing the swap myself ... my greatest worry on that front is not the removal, I'm pretty sure I can cope with that. What worries me is getting those things lined up right after the old ones have been removed and all traces of the old adhesive gone. Getting them at the right height, proper angle in reference to the truck, and perfectly straight, all at the same time and having only one crack at it makes me really nervous. :(
What I would do is get yourself some automotive tape (what I have is green and is pretty wide but I don't remember the name of it :think:) and put it on the door along the top of the current molding before you remove the original molding. Then go through the demold process leaving the tape in place so that you know exactly where the originals were. Then placing the new moldings where the old moldings were.
If you want I can check out the name of the tape I have at home. I'm pretty sure I just got it from an auto parts store and it works great and leaves no residue behind.
soulsea
soulsea
Bar
I should also add that the ltz moldings aren't as easy to install as the plastic moldings. Each door has two interlocking moldings (plastic and chrome trims) each with their own adhesive strips. So all that has to be accounted for when trying to line the darn things up.
---------- Post added at 04:04 PM ---------- Previous post was at 04:03 PM ----------
If it's not too much trouble I'd appreciate that.
dizhai
