How to install E-Fans
JennaBear
Resident Ninja
San Diego, CA
The blue wire is the perfect length to mount the relays to the PCM cover. Glad you got it all up and running!
Rivieraracing
Jenna, do you have a picture of the location you are referring to? Mine are just ziptied to another wire loom and would like to find a good spot for them!
Glad you got them going Britain, hope you like them, I love ours!
JoeOmerta
Buffalo, NY
Does the #42 pin have to be activated in order for the fans to work? If i were to install this, and not have time for a few weeks to get it turned on, will the fans still keep my a/c and engine cool without the use of an external on/off switch?
grayhoe00
GA
i am wondering the same thing.
candyman74
arnold, mo
electric fan turn on pin
i have an 01 tahoe and my question is will i be able to turn the pin on to run electric fans in my truck? a local place told me i might not have the pin on my ecm.
dwmmatt23
central valley cali
I hope you have the pin if not im S.O.L. everything i have read indicates that we do
waxworkz
ok guys i need some help!! the green wire for the ac isnt turning on my passenger side fan! it works when i test it with a test light, turn positive when i turn on the ac. but when i connect the green wire from the BB harness it doesnt do anything. seems to be not enough voltage to turn on the relay. i even tried another relay and it wont trigger them. any one have this issue before? how did you guys test for the right wire??
ScottyBoy
Shreveport, La
This is the right wire you need to connect to on the bottom of the underhood fuse block.
plush
and where do we buy these fans and harness?
jdpber
GOLD MEMBER
The America
Ok quick question. has anyone done the E fan upgrade but with a standard after market (summit, jegs) fans and wire them in and use the threw the louvers like you can get at the parts store or order Online. VS the factory housing.. i am simply curious.. i am going to try and find some factory fans but may have had no luck so far.. and this is a back up plane.. we can call it "THE PLAN B"
chip
Cincinnati
I've done it. It works great if you do it right.
bottomline2000
Dallas, TX
call me crazy, but I swear Rock Auto has the factory fans for $146! They are Dorman which is the factory brand. I'm kicking myself for not looking here before sifting through the local junkyards. I paid more for mine out of an 05 Kon.
I'm pretty sure the NNBS fans will fit the NBS since the layout is the same, even the fan motor connections. only difference seems to be the fan blade count is higher and more curved.
Had I found these earlier I would have been the guineau pig to see if they fit. FWIW I paid about $250 for my junkyard take offs..ugh.
http://www.rockauto.com/catalog/raframecatalog.php
jdpber
GOLD MEMBER
The America
can you make a better link it didnt go to the fans.. thanks
bc for that price i will order a set and call it a day..
schafer98
