another E-fan thread
tybardy
tybardy
everyone needs a Hoe
Gilbert Arizona
if it's not too late pull the radiator too as it's the larger radiator in the 05+ and the fans will bolt right up to it. you don't need a special tool to pull the clutch fan. i used a large pipe wrench and a hammer to whack the handle of the wrench to loosen the fan on my 99. used the same method to put it back on before i sold the truck and removed the fans.
goood to know mang... yea i still have not got around to doing this, i have been in super lazy mode lately! i was unaware that the 05-06 model had a bigger Rad though...
tybardy
tybardy
Gilbert Arizona
also good to know... i sure am glad i got the Z71... it would be PERFECT if it wasnt for the nasty grey trim!
Grocery Getter
A guy with a truck.
Phoenix, Az
Hmmm. Gonna pick up my e-fan assembly soon, did not know that about the radiator. I have an 04' LT not Z71 how big is the "bigger" radiator so I can measure mine and if I do, which I probably do, have the smaller radiator will the assembly still work/fit?
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
i don't remember exactly the 2 different sizes...memory serves me one is 28" and the other is 34". When I did my efans I used ls1 fans so I'm not exactly sure if the 05-06 fans will work directly over the smaller rad or not. Hopefully someone that has done this exact mod can chime in. You might check with someone at gmfs or pt.net as i know alot of the truck guys have done this mod with ls1 or oem fans.
Pat
JennaBear
Resident Ninja
San Diego, CA
You will know if you have the larger radiator, if you measure from bolt to bolt and it equals ~38". If you have the smaller radiator, I would recommend the LS1 fans like Pat mentioned.
Grocery Getter
A guy with a truck.
Phoenix, Az
Ok, if u mean bolt to bolt on the back side of the radiator at the top by the hose then Im
all good at 38"....
dec322
B'ham AL
So the thermostat is different for the 2002 model?? I'm confused now...I thought by using the harness and the PCM efan switched on, you don't ahve to do shi!t else. It seemed JKs way was to ensure when the AC clutch kicked in, the efan would also.
BOSS
I didn't feel like this question was directly addressed so I will say something to it. Initially I was confused with the talk of the new "thermostat" because I was thinking of the coolant thermostat. These are two different t-stats.
The one used for the e-fan setup goes between the fins of the radiator. It sends the temps to the fan controller and the controller turns the fans on at the set temperature.
You still retain the stock t-stat for the coolant system.
I like this method best because it would be cheaper for me. JK did his for under $150 (I think).
Now, if I had the BB tune like the OP then I would go with the 05-up fans. Not everyone can live the yukon/tahoe mod dreams.
Drewphil
