commercialfshrmn
- Joined
- Jul 9, 2026
- Posts
- 95
- Reaction score
- 87
being it's on the #8 that's going crazy, where do i begin to even look for these?I'm also leaning to a vacuum leak but got to rule out possibilities.
does it have electronic shocks? or did it have them at one time?also, wtf does this connector go into? right by the front headlight. seen it swinging around. smh
pretty sure. it's an ltzdoes it have electronic shocks? or did it have them at one time?
it might be to either the ride height sensor or the shock or abs sensor, I don't recognize the plug off hand check all around the general areapretty sure. it's an ltz
interesting.i definitely will here directly. here is nothe plce it could go, just by sight and feelit might be to either the ride height sensor or the shock or abs sensor, I don't recognize the plug off hand check all around the general area
was one of the connectors for the z55 bs. just wanted to be sure it wasn't anything serious!it might be to either the ride height sensor or the shock or abs sensor, I don't recognize the plug off hand check all around the general area
well.....i might have found my vacuum leak, lol. the airbox doesn't have the rubber grommets & wasn't in in the holes properly. map sensor, & more oem stuff & run live data again, later. will take more videos.it might be to either the ride height sensor or the shock or abs sensor, I don't recognize the plug off hand check all around the general area
