Where is the seatbelt electrical connector? & How to remove left-center vent?
mikez71
I only see one 2-pin connector under the driver seat, and the wire colors are wrong..
Where is the bugger hiding?
Also want to replace my broken dash vents, how do I remove the left center vent?
Top screw is obscured by dashboard edge..
I think unless the little fins are actually broken they just snap back into place
you talking about this one
mikez71
mikez71
That's the one. That top screw is behind the top edge of dashboard? And doesnt look look like enough space to remove a short screw, much less the long ones used..
those things are like little jigsaw puzzles I thought mine was broke just snapped it back together. unless some wings are missing
mikez71
mikez71
Awesome! Good to know, thanks for the details!
mikez71
mikez71
Well, I tried it Doub.. It took a bit of prying, but now the rear half of the vent is loose.
So back to the original plan, which probably involves lifting the dashboard.
Have thought about hogging out the edge of dash that's covered anyways, but worry it might lead to a crack later..
Who TF designs stuff like this? GM = Gotdam Mothersuckers!
mikez71
mikez71
wrong vent, it's the driver right vent.
UPDATE:
Found the seatbelt connector!
So annoying when the loud chime suddenly comes on while driving...
You have to look from above the seat, not underneath.
It's right next to the seatbelt latch if you shove the seat foam out of the way around the latch.
mikez71
mikez71
Charm.li seems to indicate that the vent comes out with the headlight switch, if I'm reading it correctly. Or am I looking at the wrong vent?
Thanks here's the right vent (center)
It says..
Remove I/P bezel
Remove I/P trim panel (dashboard?)
Rear half? you mean it's part way out?
it may be in there tight but should come out, run out to cordova and experiment on one out there. there has to be a couple dozen of them out there atleast
mikez71
mikez71
Oh, I meant the housing part.. Apparently it's two parts.
There's some small tabs on the bottom that won't grab, so the back half of vent jiggles around.
Probably wouldn't notice anything with the vent in there, but the plastic feels loose and a little air could leak out the seam..
mikez71
mikez71
Oh, and for anyone pulling the seatbelt connector. Just disconnect it.
Don't cut it off and splice it, don't ask how I know...
I think that's just how they are, but I am going off of memory from 10+ years ago
mikez71
mikez71
Installed new Dorman center vent.. Do NOT recommend.
It's floppy in the middle, and rubs on the edges when rotated to the sides.
I plan on jamming some adhesive felt under the vent to hopefully tighten it up.
Removing dash top was not too difficult.
After pulling the bezel off, remove about six 7mm screws along the edges. Passenger vents and grab handle come out.
A couple phillips screws on both ends and one behind each passenger vent, and you can pull cover back and up..
Spend the extra $10 on a used junkyard vent from ebay! (Dorman vent was $20)
jkhuntzinger
