Thanks for all the suggestions Fless, strutaeng, mountie, 6speedblazer, Scottydoggs!
And I'm surely forgetting someone.. sorry if I did!
Good news!
As Fless mentioned my MAF was not reporting right.. Too much at idle, too little at WOT.
Alvin of PCMofNC also informed me that MAF sensors age out..
Installed new MAF. Max LTFT now 9.4%, and STFT also much better. Old left, new right.
Honeycomb pattern looks different. New one has ovalized hex at different angles.. Or it's just deformed from mishandling at the factory..
MAF resistors? look a little different.
Old legs angled 45 degreess, new straight. One new resistor larger.
Idle at stop in drive, the new MAF reads 6.6g/s..(old 8g/s)
Max airflow at 5,184 rpms, new equals 260g/s..(old 213g/s - 226g/s)
Injector duty cycle 17.40ms at 5,184 rpm supposedly 75% duty cycle.
Someone with a LQ9 logged 253g/s at 5200rpm, 20.7ms, 89% duty cycle.
They also logged 265g/s at 5,530 rpm..
Old MAF - airflow signal squiggly, fuel trims jump when driving modes change
New MAF - airflow signal smoother, fuel trims change much less
