New luk torcon converter
Chris2144
So I bought this 2007 Yukon Denali with a shuddering converter. It has 161k miles. Has the 6.2 awd 6l80
I replaced the converter with the new luk converter. Tc0017
Was recommended by a shop that it’s the only one they will use for stock replacements now.
The install is straightforward no change really comes with new bolts and out of the box everything looks good.
I’ve got about 900 miles on it now and the shudder is gone, shifts nice and trans temps stay under 180.
I will say that before I did this I pulled the pan. The fluid was a little dark but not terrible and didn’t smell burnt.there was a little metal on the magnet and a slight film coating the pan. I’ve definitely seen way worse so I decided to just go ahead and replace the converter. There were no other symptoms or any codes and lime ramp up pressure looked good so I was fairly confident the overall health of the trans was at least decent.i have not tuned the trans but I will soon.
Overall it seems that this converter is very good and it’ll anyone is running into converter problems and needs a stock replacement I would def recommend it.
Picked it up at AutoZone for 427.00 no core charge.
West 1
Thanks for the feedback, my 08 Denali at 145,000 miles has just started a small oil leak at the rear main seal. Only about a large drop every night but I hate oil leaks. I will pull the trans and replace the rear main seal but I am thinking this is a great time to install a new converter.
This tranny had a new factory TECHM installed at 65,000 so maybe a new converter will keep it healthy.
Only complaint is sometimes this tranny can clunk on an acceleration downshift, not terrible but not a smooth shift. Is that just the Torque converter unlocking?
SpareParts
North Idaho
Mine had that weird clunk sometimes when going around a corner with the stock tc. After i tuned it, it took a couple of days to relearn i think, but it no longer has that clunk.
I would like a little more engine breaking going down hill in 1st and 2nd going down hill.
Can that be tuned into it?
West 1
I have been happy with the factory tranny so far staying locked in 1st and 2nd. We tow our boat into a canyon to launch. I lock it in 1st and let the tranny hold our speed all the way down to the launch. It is maybe 3 miles pretty steep downhill on a narrow twisting road. So far the tranny has worked just fine for that use. Mine is a 2008 6L80 behind a 6.2L., previously towed with our 03 and 4L60 trans, both did this job fine.
We went to visit Pikes Peak but were driving a rented Ford Fusion. On the downhill coming down from Pikes peak, 14,000 ft or so. The Tranny would not hold at all in 1st gear kept upshifting. We were forced to use the brakes and they overheated. Had to stop for a half hour to let them cool enough to continue. I do not understand how a factory could sell a car with that tranny feature. It was flat out dangerous. Does your tranny upshift like that Sparparts?
SpareParts
North Idaho
No, it works great everyplace honestly. Maybe what im looking for is in the engine tune?
In the wife's 2013 Avalanche going down a steep hill in M1 it feels like when the engine speeds gets up to say 2.5K rpm it feels like it starts breaking harder. My 07 Yukon XL does not do that. Maybe my imagination?
Both stay in whatever gear i manually tell it to.
mikez71
Thought I heard they added grade braking in the '13-'14 models?
AFAIK there is no way to tune that feature.. idk
I do notice that in our 5.3 tunes, the tcc apply ramp has some big values for negative slip...
(but small for positive slip.. ?)
And if you look at 6.2 tunes, it's opposite.
Although they added a little bump for negative slip in the later years.
'08 6.2
'13 6.2
But also, the 5.3 does not lock TCC in 1st, while the 6.2 does not lock in 1st & 2nd.
Geotrash
Dave
Richmond, VA
On an ‘08 Denali, clunking on a downshift is most likely to be (in order of probability):
1/ Driver’s side motor mount
2/ Front differential mount bracket bushings
3/ Transfer case chain slop
This has been the case for other folks here, and it was the case on my ‘07. I addressed 1&2 a few years ago which took care of my clunk on downshift problem. Now I have a clunk when coasting and I hit the gas to accelerate, but no downshift needs to be happening. It’s pure driveline slack, and chassis ears tell me it’s the transfer case, which has a ton of slop in the input shaft, and indicates significant chain/sprocket wear internally at 253K.
I’ll eventually address it but just haven’t yet.
West 1
Food for thought. Driver Motor mount is new. I have had the front differential out and re installed after rebuild, did not even consider wear in the mounts, that may be an issue. At only 145K or so I think the transfer case should be fine, fluid is new and old fluid was pretty clean. Thanks for the tips.
C
Chris2144
Unfortunately I cannot attest to any kind hard shift or clunking as this trans was working fine other than the tc in lockup would shudder. Judging from others that have had the tc problem I think I caught this one early which is why I didn’t see any other symptoms
Bronson357
I don't think a corner has anything to do with the trans. Axle?
West 1
Found some information about the Luk Torque Converter. I am thinking that will be my choice at this point. I like the rating of 1,000 ft pounds of torque.
Should handle the 6.2L no problem.
The All New LuK TorCon from Schaeffler​
  • The first brand-new torque converter in the automotive aftermarket
  • All new converters → All new components → No contamination
  • Unwavering performance through a consistent build process
  • Premium Materials
    • Industry-leading LuK friction material
    • Best-in-class INA thrust bearings
    • Fully furnace-brazed fins
  • 100% functionally tested
    • Pressure & lockup tested
    • Precision balanced
  • Longer life and durability
  • No Core Charge/Management - Simplified Inventory; no cores, no components
  • SKU Consolidation – reduce inventory and time finding parts.
  • 12/12 Warranty; 1 year & 12,000 miles
The LuK TorCon 6L80 is the only brand-new torque converter in the automotive aftermarket industry. Designed to significantly reduce fuel consumption and emissions, it fits common vehicles with 5- or 6-gear transmissions. The coordinated interaction of housing, lock-up clutch, turbine wheel with torsional vibration damper, thrust bearing, plus guide wheel and pump ensure optimal operational efficiency, as well as excellent functionality and durability.
The new patent-pending design offers improved reliability in a smaller, more efficient package capable of handling up to 1,000 Nm of torque. Engineered from high-quality Schaeffler friction material, the LuK 6L80 offers longer life, fewer replacements, and is suitable for the continuous-apply-strategy of the 6L family of applications.
The drive plate is constructed with 12 mounting points to eliminate warping and distortion of the cover - a more complete solution than rebuilding a worn converter. Schaeffler’s updated design has been proven to last 5x as long as a rebuilt converter. When you install our fully updated converter, you can say ‘goodbye’ to failures.
Foggy
KS
  • Premium Materials
On the torque rating: I don't know how much is 1,000 NM of Torque
It's certainly not 1000 Lb Ft for sure
There are very few converter companies that would even advertise a lock up
TC that could handle 1,000 lb ft or HP and those would be very high end
racing converters for sure.
I have done a bit of reading that this new converter is very good... I'd prob
give it a try IF they offered it in just a slightly higher stall than "stock" .
Like about 2000 rpm would be fine with me !!!
Foggy
KS
'08 6.2
'13 6.2
My Yukon Denali does indeed have grade braking stock when in Tow/Haul Mode
I have never seen any tabs/info in HPTuners that addresses any type of setting though
C
Chris2144
Parameters under the special or different modes should be you’re tow haul I think those shift speeds and lock up speeds are different I’d have to go back and look
C
Chris2144
So far my luk converter has been doing great. Only have a few thousand miles on it but no more shudder and trans seems to work like normal
Foggy
KS
Yes, the lock up speeds & shift mph, etc are specific to the tow mode and are
able to be changed... But the "grade braking" is not
West 1
I received my new Luk converter today. Plan to do that job in the next couple weeks along with the rear main seal.
Glad yours worked out Chris.
C
Chris2144
I still have not got to tune mine but when I get back home I will.
With the stock tune it is performing great though.
Once I get 5-10k miles on it I’ll have to come back and give an update but I think it will still be going strong.
You might want to buy a new seal for the input shaft when replacing the converter as well as the o ring. Would suck to have to do it all over again.
Also when removing the exhaust my collector stud nuts were siezed badly. All the lube and heat wasn’t getting it loose one stud started to back out then broke and the other one stripped out. I ended up cutting the pipes on either side of the trans then cut off the remaining stud once I had the trans out with more room to work and went and bought new manifolds then welded the exhaust back up when I was done. just an fyi it was much easier to install new manifolds then fight with the collector nuts.
donjetman
when I did my rms job and torque converter in 2018 I also changed:
Tranny front pump seal – GM# 24237531 - $30
Tranny Input shaft seal – GM# 24219390 - $10
Today its till dry as a bone undrneath :)
West 1
Not sure how I missed these last two notes before I did this job. I should have thought about the pump seals. Job is complete now along with several other projects on the same truck. Back on the road. New converter feels great. Drives stock on drive offs, around town the lock up seems much more positive. Holds the lock longer than stock? I thought that was computer controlled? I actually like it, you can accelerate lightly and feel it is still Locke up. Did not do that with the old converter nearly as much. Only 3 days driving so far but very happy with the results. The Luk is behind a 6.2L that runs a 6L80 trans in a Yukon. Happy for sure so far. Thanks for the tips. No tune at this time all bone stock. It did get an updated Techm installed by GM a while back maybe it is programmed better than the 2008 factory Techm?
Charlie21ny
