Trans tuning
C
Chris2144
So to sum it up
•replace torque converter with something better than stock.
•tune the trans with a tuner such as black bear or yourself.
•change the trans thermostat or flip the inside piece over.
For just a stock trans this should get a pretty solid 6l80
Marky Dissod
So to sum it up:
•tune the trans with a tuner such as blackbear, or yourself.
For just a stock trans this should get a pretty solid 6L80
•When you replace the torque converter, make sure the CLUTCH materials are superior to GM OE, since the clutch is THE major failure mode
•There's a lot that goes into 'Tune the trans'; most canned tunes leave out almost everything EXCEPT the blatantly obvious stuff
•Yep
•Change the ATF every 40,000 miles or less
C
Chris2144
Yea changing the atf is something I’m sure a lot of people forget about.
The luk tc is supposed to have better clutches idk time will tell I guess but they have a good track record so far.
I’m ready to get this tune put in so I can see how the trans responds to it
Charlie207
LFOD, New Hampshire
So to sum it up
The 6L80s in GMT900 SUVs (up to 2014) don't have the thermostat in the transmission oil cooler lines like the 2015+ SUVs do, so you don't need to worry about that.
C
Chris2144
Well that’s nice to know I was going to go looking for it lol.
Explains why my temps are always good
Marky Dissod
Well that’s nice to know I was going to go looking for it.
Explains why my temps are always good.
Don't forget that you can keep the coolant (and therefore the engine oil & ATF) cooler by turning on the fans a bit sooner than GM OE spec.
CRN_25
