What to use to plug oil pan relief?
thefrey
What I ordered online doesn’t fit my relief valve hole… What are some good alternatives that you can get asap? Find a bolt at the hardware store?
lspann3525
I would try hardware stores or even lowes and try to get a short bolt like above.
hopefully they have the same size threads because its not hard to damage the oil pan.
when I need special bolts we have bolt warehouses here where you can get bolts in different sizes/lengths and grades
kbuskill
NE. FL.
For a VW but fits the pressure relief valve inside the LS oil pan.
thefrey
thefrey
Thanks for this. Gives me a good idea of thread pattern and length so I have a good idea of where to look at a hardware store
Summit Racing sells them for sure, made specifically for that purpose. Just order the delete plug that is specific to your motor.
solli5pack
This comment saved me. Thanks a lot!
I couldn't find a size M14 1.5 pitch bolt at any hardware stores... Then this comment popped up in my brain. Dorman sells a M14 x 1.5 oil plug at auto parts stores that is the perfect length and has a crush washer.
Good to hear. Make sure you post back and let us know what the oil pressure is when you get it running!
MoundMedic7
