West 1
- Joined
- Jan 20, 2023
- Posts
- 705
- Reaction score
- 1,516
How are you liking your new puddle lights? Which ones did you end up going with?I have some ordered already. Not that brand though.
Few weeks ago i took the tahoe to the ol desert property, used the tahoe for more space and loaded up 4 5 gallon buckets filled with water so i could refill the camper.
The week before that i put it into auto 4x4 in order to not spin tires on the wet boat ramp.
I of course forgot about that, and before the property trip i remembered about auto being set. So I turned the knob while being in a big rush to gtfo.
Headed up there the tahoe did great, but it felt like i didn't have as much power as mormal.
Doing like 80-90mph.
I come up to the last fuel stop and go "wow what happened to my gas mileage"
So i exit to top off, i ended up needing to make a tight turn and the front wheels were binding a bit.
I think "gee it feels like I'm in 4x4..."
I start fueling and thinking about the weirdness.
And i notice my tires look, umm like I drove in 4x4 on dry pavement.
So i check the knob for good measure.
I see it.
In my rush, 4 high was selected instead of 2 high.
That's the second time i have done that, but this was the furthest i have ever driven.
I wish gm put a fkn idiot light, this idiot needs a damn 4x4 light!!
The jeep has one, my old s10 had it.
The s10 also had the buttons in the center of the dash.
The tahoe, it's this stupid knob with tiny letters, that's hard to see when driving.
I changed the transfer case oil, it had color in there.
Probably clutch material.
Oh well, so far it's still working great... lol
I use a resonator when i want less rasp and drone noise.About to cut & weld a single 3.5" catalytic converter into the exhaust. I don't need it, but I think it'll help with the stink, and maybe cut down on a little bit of the rasp.
It's a 100-cell race cat., so I'm guessing there won't be much of a flow penalty with a 4.5" diameter body.
I have a Dynomax Bullet in-line, before my main muffler, and it does cut down on the rasp so I'm hoping the cat. will add enough reduction so I can just hear the furious noise of my ~300-450hp... Because who knows how much it really makes.I use a resonator when i want less rasp and drone noise.
Bottle Style Resonators
Vibrant Performance standard bottle style resonators are round bodied, densely packed with our premium multi-layered sound absorption materials, and manufactured from 304 stainless steel for optimum durability and corrosion resistance. Vibrant Performance standard bottle style resonators have a...vibrantperformance.com
I swapped out my cigarette lighters for switched USB-A and USB-C outlets. I had to enlarge the holes a little and do some cutting on the bezel to make room for the retaining nuts. But they fit and look factory if you ignore the color mismatch of the LEDs.
Closeup of surgery. This cutout allows the nut to align with the hole so everything ends up square.
Connections made. I'm liking this Deutsch connector kit I bought when I fixed the headlights. A couple of 2-conductor plugs did the trick. I bought this part at LKQ and kept the original just in case.
They're backlit blue when on. Now I can switch off devices that are plugged in rather than unplugging them.
I’d better recheck the balancer nose distance at the snout, before installing the correct ARP bolt. Granted it shouldn’t have moved, since the longer bolt bottomed out before the head even touched the washer.
