PULLING MY HAIR OVER A P0301 code!!
opfor2
Riverside County, CA
Another curiosity is that the OBD port is hot sometimes. Even with the truck off, I can sometimes connect to the OBD reader and the truck although, as it's off, there aren't any readings obviously. Unless I am truly losing my mind over this.
The 8th digit is a 0
If you have issues with your OBD port being dead check fuse 53 in the engine compartment.
57210chevy
This whole thing has me regretting buying this PPV. I've never had a simple misfire not be fixed with a plug alone, in some cases the wire, and in rare cases the coil.
It's chewing through gas like it was free. I can't seem to locate the cause of the misfire. It smells HEAVILY of raw fuel and shakes like it's going through withdrawals.
Here are new details I have. The codes are now:
P0301 misfire #1 cylinder
P0446 EVAP System Vent Control
P0461 Fuel Level Sensor "A" Circuit Range/Performance
P0463 Fuel Sensor "A" Circuit High
The odd thing is that looking at recorded 'live' data from the OBD scanner, I'm not seeing a misfire on #1, but I am seeing misfires on 2, 3, 5, and 7. Sometimes 3. All plugs and wires have been changed on 1, 3, 5, 7, and 2. (NGK G-Power plugs and generic 10.5mm silicone wires)
I cleared the codes, restarted the truck and THE SECOND the CEL comes on, I hear a noise coming from the rear of the truck (thinking it might be the Canister Purge Valve making that whine.) I'm not sure at this point. It is a kind of hum. I can re-create it by clearing the codes and starting the truck up again and waiting less than 30 seconds.
I have also begun to think that it might be a clogged PCV system that is causing the misfire, along with perhaps the Canister Purge Solenoid under the hood.
What do y'all think?? Could it be a partially clogged fuel filter?
I don't want to just throw a flurry of parts at this, but I'm getting desperate enough to start just throwing parts at this thing. And the 'coincidental' fuel gauge failure isn't helping as my wife is having to still drive this thing 30 miles a day to/from work and I troubleshoot once It's cooled down.
When I checked the oil level a couple of weeks ago before this all began, it was just oil, no milkshake.
I also put about 1.5 cups worth of acetone in the tank to 'superclean' the injectors.
i did this acetone trick before smoked my fuel regulator on a 04 silverado there is a vacuum line attached to it that was dumping fuel into the intake theres your problem pull the vac line see the fuel replace the regulator and unless the fuel is dumped see it fail again ask how i know
The OP's vehicle is a much later model, without the vacuum fuel pressure regulator. It would be good to keep these recommendations applicable to the vehicle in question.
ReaperHWK
All this and you haven’t changed the injectors yet? Or did I miss that?
PBandJs_PPV
PBandJs_PPV
Fort Worth, Texas
The acetone destroyed the fuel regulator?
PBandJs_PPV
PBandJs_PPV
Fort Worth, Texas
Okay, just went from bad to worse. I took her for a quick test drive and she started smoking just as I pulled back up my street. Popped the hood and found this.
Is this a line that leads to the heater core?
Tonyv__
Bucks county PA
Sigh... I was dreading having to take the cover off, but in reality, I will KNOW either way at that point.
I'll at least remove the question mark in my head.
I chased my misfire for months. (It was my work vehicle so I couldn’t really spare the time to put her down for days or send it to the shop). I finally decided to pull the valve covers and could physically feel the difference on the rocker of the cylinder in question. At this point I knew it was mechanical.
It’s a pain in the Ass but it might answer some questions sooner than later.
PBandJs_PPV
PBandJs_PPV
Fort Worth, Texas
Connects to the rear heater pipe (one of two). If you don't have those two heater pipes then the fitting is not the correct one for your application.
I don't know. I haven't even looked yet. But thank you for the heads-up! I didn't know there were two possible configurations.
PBandJs_PPV
PBandJs_PPV
Fort Worth, Texas
I went ahead and cut the other hose, that was perfectly fine because I decided to upgrade to the metal hardware. Go in, and never again.
PBandJs_PPV
PBandJs_PPV
Fort Worth, Texas
I still have P0301 thrown BUT not getting an actual misfire on #1 per Real Time Live Monitoring. RTLM is showing a misfire on 2 and 5 which I cannot get rid of. I've changed the plugs and upgraded the plug wires to 10.5mm silicone. Placing a new coil at either position changed nothing.
I've attached OBD screenshots that are showing Bank 1 and Bank 2 Sensor 2 issues. I'm also showing only 43.51psi of injector rail pressure. Think I'll replace the fuel filter and see if there is any change. Either way, I think I'll gut the catalytic converters because, they just suck.
I also attached the Recorded Data in an Excel/Sheets format.
  • 2025-05-27 17-13-21.zip
TollKeeper
Brighton, CO
What’s dead about it?
Likely no compression.
I mean in all honesty.. you have 3 options.. Listed from cheapest to most expensive
1: Unplug the injector, and deal with it, ongoing check engine light, poor fuel economy, etc.
2: Find a used engine.
3: Get a new engine/ Rebuild your current engine.
Tonyv__
Bucks county PA
I’m just wondering if they provided any info on what they think it might be.
jkhuntzinger
