Cleaning exterior rubber seals and trim pieces
Lonny
Hi guys -
Some of the black rubber gaskets and seals around the windows and roof area of my Escalade are turning grayish white. I'm wondering what you recommend to restore them to black. Please let me know what you think - thanks!
Lon White
Hi guys -
Lon White
I have always used just 409 and a soft towel to clean them, the oem protectant fluid is super expensive, it's basically gpl-106 pfpe oil a small 7oz bottle from germany I think cost me around $40 it's called krytox, the oem stuff is a different name but cost even more, but it is also basically gpl-106.
the same stuff I bought is now around $65.00
mountie
My roof rack..... This protectant worked perfect..... Not glossy.....
( I also use it on my tires..... not glossy,.... makes them appear new. )
L
Lonny
Thanks guys!! Are you masking the paint before applying?
Stbentoak
many things work... but all of them are only temporary. Replacing them is the only semi-permanent way to fix for a good while..But really isn't logical expense wise. I've used any and all of the above for a temp fix and have learned to live with it....
KMeloney
If they're turning grayish-white, then you've been using something on them that is terrible for them (I'm betting Armor-All), and they're likely already toast.
I ONLY use Lemon Pledge (yes, the furniture polish) on black trim. It does an excellent job of maintaining and protecting the trim's finish. It will not degrade the trim finish like the other crap does.
You're welcome.
TxVet33
Abilene, TX
Hi guys -
Lon White
Doing This Will Make Your Car's Suspension Last Forever, DIY life hack and car repair with auto mechanic Scotty Kilmer. Car life hacks. How to save thousands of dollars by not having to go to an auto mechanic for car suspension repairs. Expensive suspension repairs. Car hacks that will save you thousands in suspension repairs. 5 minute life hacks to make your suspension last as long as possible. Make your car's suspension last forever. Suspension maintenance tips. Car advice. DIY car repair with Scotty Kilmer, an auto mechanic for the last 53 years.
AT 205 Reseal: https://amzn.to/2Iss794
KMeloney
I got the impression that the OP was looking for a cosmetic fix for his trim pieces (and not necessarily something that restores the rubber's pliability). But maybe the OP will chime in again.
TxVet33
Abilene, TX
Some of the **black "rubber" gaskets and "seals" around the windows and roof area of my Escalade are turning grayish white. I'm wondering what you recommend to restore them to black. Please let me know what you think - thanks!
Lon White
KMeloney
Lon White
Right. Not sure what you're saying/asking.
ASG-MikeS
