Front diff looks great per the magnet anyway
Sir_Hiro
Junkyard run was a success.
Got a upper denali grille for 30 bucks. Lower was destroyed.
A new rear window switch to replace broken. All in all a good day.
Headlights are next on the list to buy. Found the mounting tab on the passenger side is busted plus they are way to sunbaked to recover
RooTBeeRthe1st
Got to work about 45 minutes early so parked and idled with the heater on and took a little nap.
Got out and realized there was a decent little puddle under the front end so my Cold Case radiator must be leaking worse than it used to.
So just ordered another one and it'll probably be here tomorrow or Wednesday at the latest.
Swap them out hopefully I don't need to buy a new fan shroud since I had to modify the old one.
See how bad it is and either clean and braze it myself or just drop it at a radiator shop and have them weld it back shut.
bobsburban
Baby got new shoes - Falken A/T4W Wildpeaks in 285-70-17.
...and brake calipers, brake shoes, Brembo brake rotors, and front hubs. Found out some 285/70-17s are more 285/70-17 than others. These are in the more category - a full 33" in diameter and even with the PO's ride height adjustment I had to cut some inner fender to clear them.
Geotrash
Dave
Richmond, VA
I'm pretty sure those things are brazed with gouda cheese at the factory. I replaced my leaky 2.5-year-old Cold Case with a Denso and haven't looked back.
carman2197
