man, just had a derp moment, for whatever reason I thought I had bought mobile 1, tossed my receipt but I used my phone number maybe I can exchange them, grrGrabbed a couple qts to do the front diff
I still have my dad's 1/2" Craftsman breaker bar from the 1950's. It's nigh unbreakable.the craftsmans line went to crap long before the name was sold off. big difference between vintage craftsman and the later stuff. there's a market for the old stuff if you have it. the newer stuff wasn't made as well.) it's noticeable side by side.
What would be the difference?man, just had a derp moment, for whatever reason I thought I had bought mobile 1, tossed my receipt but I used my phone number maybe I can exchange them, grr
probably no difference, I just thought I had grabbed m1 lol. I will just use thisWhat would be the difference?
As long as they are the same formula the Valvoline should be fine.
Most of what I've seen for Mobil1 is like Monster Cable for audio stuff, just the name.
Unless you've seen real world testing from someone like Dana that proved a tremendous difference, I wouldn't think there would be a difference.
Only case I have seen where Mobil1 made a significant difference is with Nissan VQ engines.probably no difference, I just thought I had grabbed m1 lol. I will just use this
Not surprised, though I used to run it exclusively back then and got 300K out of an Isuzu V6 that usually threw rod bearings at around half that mileage. Mobil1 was also marketed in a shady way. The base oil stock was actually dino juice that they re-processed and labeled as "synthetic". Not sure if that's still the case but I stopped using it and started using Walmart real synthetic oil instead.Only case I have seen where Mobil1 made a significant difference is with Nissan VQ engines.
Someone had some repeated Blackstone testing done and with Mobil1 there was an increase of brass in the used oil.
Other synthetic oils didn't show this so Blackstone surmised the Mobil1 wasn't protecting something as well as other oils.
They guessed cam bearings.
Granted, this was back around 2004 so things may have changed with their oils.
My guess is that either the ones you ordered may have been spec'd to fit but in reality were too short, or they have an internal fault preventing them from moving smoothly through their full range of motion.Yesterday, I installed some new rear hatch supports.
After they were both in, when the lift gate would go up, it would clunk at the top like it was being pushed too far by the new lift struts.
The gate would go up and stop like normal, then clunk and jump just a little more.
I removed the new struts and reinstalled the old ones because I didn't want to damage the lifting mechanism.
Guess I'll have to order genuine GM struts and see if the same thing happens.
Only reason I ordered the new ones is the auto lift function doesn't work when it's near zero degrees or colder and I wanted to see if new struts would and make any difference.
It's almost like the new struts were pushing the lift gate up too far.My guess is that either the ones you ordered may have been spec'd to fit but in reality were too short, or they have an internal fault preventing them from moving smoothly through their full range of motion.
I've used aftermarket struts on these many times and had great results. The only ones that didn't work right were the ones I got at Autozone.
These worked well for me last time and are still on the vehicle.
based on 27,000 miles of dataI was just trying to figure out why my tread (off-road gps) showed so much travel time difference, because that stupid thing has "adventurous mode" level 1-4 which it calculates a route based on on-road/off-road on it's own some weird thing it does, I like it because it has newer features but takes some different paths sometimes.reminds me of an old mitch headburg bit about oatmeal. something about making instant oatmeal and then sitting around for and hour not doing shit. makes me think I could make normal oatmeal and feel productive.
You do realize it’s the journey, not the destination?I was messing around with my GPS's I have and discovered I trim 2 hours off of a 700 mile drive
a 700 mile drive should take roughly 11 hours, I do it in 9 hoursbased on 27,000 miles of data
weird that it is only about 14 mph difference
sometimes.....been up and down the west coast many, many, many, many times. car, bus, airplane, dump truckYou do realize it’s the journey, not the destination?![]()
How about a link?Got my new tires put on today and these clips arrived in the mail from mouser, when I was doing the front end work I had to take the abs harness off at the frame because I didn't want to unscrew it from the hub, the plastic clips where the harness connects on the frame were brittle and broke right off, I was looking at ones out at the junkyard and they were all brittle too and broke when I tried to take them off, figured out how to detach the clip from the harness and used google lens and found these for 52 cents on mouser. I don't think gm sells these separate. 100% identical part made by hellerman tyton
View attachment 452530View attachment 452531
Wow, that thing was nasty.Replaced the VLOM and oil sender unit. Here’s a good video link that I followed to easily DIY it and a few pictures of a 162k VLOM with regular oil changes.
View attachment 452574View attachment 452575View attachment 452576View attachment 452577
How about a link?
I already have a Mouser account so I could preemptively order some.
I recently order two new PSUs for my cousin's audio interface in his studio.
They were direct replacements for his old one and got his $3k piece of gear back up and running.
