Need support. Just found out my radiator is leaking
iboughtatahoe23
iboughtatahoe23
Ya still dripping coolant to. Only seen two drops on the cardboard. Maybe leftover but idk I rinsed it than when I dabbed it on my tongue it shouldn’t have been so concentrated and bitter. I was expecting it to be watered down who knows. At this point I’ll keep a eye on it
iboughtatahoe23
iboughtatahoe23
those transmission line brackets can generally be tweaked a little if necessary
Yeah, and I don’t see any leaking from the lines. All I see is the fluids leaking from that tray under the radiator, and I never
Dried or rinsed that out after emptying the fluid from the radiator, until I went to lightly spray it out earlier… now I’m here.
iboughtatahoe23
iboughtatahoe23
Br0ther
Well, remember, I think they’re still cooling in the block right I never drained the block
Plus the lines to the back of the truck and both heater cores. That’s why I said 3 gallons and not the 4 3/4 the system holds duh. :p Sounds like you got it licked. :emotions33:
iboughtatahoe23
iboughtatahoe23
Doesn't look a lot like coolant to me, but you could pressure test the system to see if it's actually losing pressure.
The drip on the cardboard looks like transmission fluid, or maybe weak Dexcool.
There was some trans fluid. Not seeing any anymore. I’ll keep an eye on the level I suppose tho. As well as my coolant reservoir. I think I should take it into the shop and have my guy double over my work
iboughtatahoe23
iboughtatahoe23
looks like residual water, give it a couple days to dry out
I was gonna try using an air compressor to blow the pan underneath the radiator. Whatever that metal thing is. That’s where it is coming from. Like the first photos I showed yall when I found the leak.
Like Wes said, when you pull the lower hose off the old coolant goes everywhere and can drip for awhile afterwards. Wait a few days and then try the cardboard under there. If you hosed it off in that area it will be water mixed with coolant dripping otherwise it can be straight coolant. I never used any cardboard to check because I knew things would probably drip a few drops for awhile. That stuff seems to go everywhere and there’s lots of places for it to hide and slowly drip until it’s gone.
iboughtatahoe23
iboughtatahoe23
I got under and took of the shield and it looks like it’s leaking in the same spots.
This isn’t a current image, this is before I changed radiators. A couple days ago But it’s the same area kinda, there’s little drops forming on the harness there. And even
After I lightly sprayed down the area with a wide nozzle.
I got under and took of the shield and it looks like it’s leaking in the same spots. View attachment 451406
It might have got into the harness and it’s still dripping out. Patience. Wait a couple three days without spraying anything else in there, then use your cardboard. Watch the level in the overflow tank.
scottd
