Oil Pressure
West 1
I have a 2003 GMC Yukon 5.3L with 130,000 miles on it. Developed a couple oil leaks, seems to be coming from the pan gasket. There is a little oil below the rear main seal but looks dry around the flex plate and torque converter.
Previously at 100,000 miles and 8 years ago I pulled the timing cover and installed a Melling M295 Oil pump and a new Oring. Doing this from the front the factory oil pan and gasket stayed in place, was good but has now developed small leaks. Not a lot but I hate oil spots on my driveway.
With the new Melling pump at 100,000 miles I had good oil pressure, 30 psi hot idle and 40-60 psi hot at RPM depending on what RPM you were running but oil pressure was a little less than before the new pump install? That always bugged me a little.
I have the Melling M295 Oil Pump in the truck, this pump comes with a standard Spring installed (as advertised) and 2 optional springs for lower or higher oil pressure come in the box. I believe Melling says the 3 springs offer 50, 60 and 70 PSI.
Since the pan was off I decided to go ahead and pull the timing cover again and change the pump pressure relief spring. I wanted better oil pressure at idle.
On removal I was surprised to find that the M295 had the lower pressure spring installed from the factory? It was supposed to have the middle pressure spring installed. Easy to tell which spring is which since they differ by length. Longer = more pressure.
I debated but decided to go with the longest spring. Fired it up tonight. Wow, cold start oil pressure was about 75 psi at idle! Fully warmed up idle oil pressure is still 65 PSI by my gauge in the dash. Formerly it was 30 PSI hot idle oil pressure.
If it was not so much work to go back and change it I would choose the middle length spring which I think would have me at 55 PSI Hot idle Oil Pressure. I wanted to post this so others might make a better decision than I did.
I should also share that when I did my Oil pump install we also did my buddy's truck, he had 270,000 miles on it and suddenly had zero oil pressure on start up. His truck motivated us to change pumps on both trucks at the same time.
At 270,000 miles his truck had 60 PSI hot oil pressure at idle, mine at 100,000 miles was below 40 PSI at hot idle? We did both pumps from the front to save time. It worked and was less time than pulling the oil pan off.
With the slightly lower oil pressure when I installed the new pump at 100,000 miles I was afraid maybe my engine bearings were starting to go bad but that is now ruled out, to have 65 psi at idle oil pressure the bearings have to be tight still so that is very good.
I will share that I had started using 10-40 synthetic to get the pressure up over 30 at idle and that is what is in it right now so I know I can cut back to a 5-30w now and oil pressure will come down maybe 5-10 PSI so I will do that but just wanted others to know what I found.
One more possible issue found on tear down. The Oring installed at 100,000 miles was the Melling supplied green O Ring which is recommended for the tapered pick up tube I found in my truck. On tear down the tube dropped right out when the bolts were removed. I did not have to pull to get the pick up out of the pump. The Oring was flattened by heat and time but it really only had 30,000 miles on it. This Time on install I used a Fel-Pro Red Oring hoping to get better seal. My guess is maybe the green Oring was weak from the start? The red new oring seals better? Oil pressure always built up quickly at start up in this truck even with the green O ring indicating the O Ring was sealing, was never slow to build start up oil pressure as I have seen on other trucks due to old hard orings.
The good news is Oil pressure is very solid now, the leaks in the oil pan gasket witnessed along both side rails are fixed. Bad news. There is a small drip from the Rear Main seal gasket which I had hoped was from the oil pan at the rear. Damn. The tranny will need to be removed to fix that one at a later date. It was leaving 3 small oil spots before it is down to only one small oil spot. More fun for a later date I guess. I hate oil spots. I hope this helps others or at least offers entertainment! Mark
strutaeng
Dallas, Texas
Your pressure at idle seems just fine. Unless trash runs through the oil pumps, they don't really wear much, if it all. I tore down my LQ4 with 260,000 miles and the pump looked pristine, so I cleaned it up and reinstalled. Bearings are what usually what affects oil pressure the most.
I'd be more worried about the rear main seal. It's not uncommon to leak but the flexplate looks dry. I think the centrifugal force of the spinning flexplate causes oil to fling everywhere . Put some dye in the oil and check with a UV light. Look through the flexplate holes and you may see the leak, but even then it's hard to spot.
justirv
There's a good possibility that your trans will need in-depth attention around 150k-175k, so while taking care of the RMS, consider rebuilding it while it's out. Have you addressed the oil cooler block-off plate? It always makes a mess until its replaced with a solid billet piece, gasket replacement with the stock (warped) plate doesn't seal long.
strutaeng
Dallas, Texas
I'm at 266k on the transmission and it's the original as far as I can tell. I should have mentioned it's a 4L80e... :)
I have considered rebuilding the transmission down the road, just so that I get a new set of bushings into. I believe there's a bit of wear from the crankshaft lowering a few thousands as engine crankshaft main bearings wear, which goes each way (engine and transmission).
justirv
4L80e, please disregard my former comment...
West 1
West 1
I should have shared that the main reason I looked at the Oil pump again was an issue I had while towing heavy loads, My oil pressure would start dropping when pulling heavy loads in the summer. I pulled 7,000 pounds 550 miles when it was 95*, went over several passes with one at 8,000 feet. Oil pressure dropped to 30 while pulling the long hill in 2nd gear and revving 4,500 RPM for about 5 minutes. Made me nervous. I know, hot oil is thinner but I thought with better pressure initially the engine would be safer. My engine does not have the oil cooler option and I rarely tow a heavy load but this was motivation to increase my oil pressure. Mission accomplished but a tad higher than planned.
a1parrothead
