Reading all this.. if clearances are a problem on pistons… it seems to me that a 207 deg was what 2018 l83 had… is that still what it is on the 2024s? I know you get down south.. the gm cooling is weak..
It seems to me that the video perfectly confirms my version about small gaps. 4 miles, Oil pump ok, crankshaft ok. The piston seat fell apart because it was difficult for it to move in the cylinder
Look, this is a photo of a new engine that just arrived for service the other day. Engine out of the box, mileage 0 km. There are already scratches on the cylinder mirror and marks on the liners.The failure mechanism was not oil related or clearance related on this specific engine. It appears that the wrist pin C clip was either missing or installed incorrectly, or the piston C clip groove was not machined in the wrist pin hole, so this would likely be considered manufacturing or an assembly problem. This piston was in the rear of the engine, so likely cylinder #7 or #8. The missing clip allowed the piston wrist pin to walk sideways and then the piston became bound or cocked in the cylinder and caused the piston to become bound in the cylinder. Then the weak link in the chain was the connecting rod which broke. I believe these connecting rods are not forged steel but compressed sintered iron.
This is the style of the piston wrist pin retaining clip, not an ideal style based upon what I have dealt with over the years:
What is a bit surprising is that GM did not want this 4 mile engine returned for failure analysis. As the shop that received the engine noted the oil pan was already off so it was unclear if the piston wrist pin C clip fell out or was actually missing. Based on the style of wrist pin C clips, they are not what I would call severe duty or high performance. They just appear to be round wire curved clips.
This may have been a small percentage assembly failure or it may have been a more common failure.
Here is another good video that allows you to see what a higher mileage failure looks like. In this engine it appears the #1 rod bearing failed or spun that likely led to the catastrophic failure. But in any event it allows forum members to see what is inside these engines.
The fact of the matter is that our service disassembles a completely new engine from the box, grinds out the gaps, checks all the tightness and reassembles the engine)))You clearly have pictures of a new engine. While I am not there to personally inspect and "feel" the finish, what I am seeing is not significantly concerning. Could things look better, sure they could.
So understand at the engine assembly plant they "Cold Test" newly build engines by spinning them with a large electric motor and they measure intake and exhaust airflow as well as the torque required to turn the engine with the electric motor to determine if the build is within the spec range they expect.
I assume this "Cold Test" is performed with oil in the crankcase, but it is unclear if the oil system is pre-primed or if the "Cold Test" starts at a slower RMP to build oil pressure then to increase RPM after a specific number of engine revolutions. No idea if the oil is pre-warmed before the engine is filled with oil, I hope is would be.
Seems that there is something either with the initial build on these engines or something with parts that may be causing problems. I would be interested to know if your shop actually checks the original build bearing clearances with Plastigauge to figure out if the engines bearings are too tight or too loose.
That is a gnarly looking bearing. Doesn’t look like debris or oil starvation. That actually looks like a defect bearing delaminatingInteresting YouTube video, while this is a 2017 6.2l with over 100k miles, the engine is VERY clean and it appears only 1 bearing had any issues. The main bearing cap was not removed in the video and it is unclear if any of the cam bearings started to flake or fail. From the metal in the oil pan, it looks like more than just from the one rod bearing.
If I was rebuilding or reworking new engines, I would likely go with King Engine Bearings. Even if buying a new motor, I would likely at least replace the main and rod bearings.
I wonder if the same style of bearings were used in the 1999-2006 6.0l engines. I have one that is over 275k miles and still going without lifter or bearing issues.
I got a brand new Tahoe in January, 2024, and in November I had a catastrophic engine event with the 5.3L. I got stalled with a child in the middle of a busy intersection and it took a month for them to get my engine replaced. The service tech believes the fuel management system broke down starving the engine of fuel and causing a piston to break off.
I have owned vehicles for nearly 30 years and never had anything close to this happening. Is this recall for the 5.3 and 6.2?
Well I am not seeing this as the case. Maybe I have wrong, outdated information, but what I have been able to find does not confirm this.The 5.3 has the 2 stage oil pump also.
LSPI really isn't an issue with atmospheric engines. Forced induction different story.Kind of thinking the 2017 engine with over 100k suffering from a failed rod bearing could be due to Low Speed Pre Ignition (LSPI)?? LSPI in conjunction with 0W20 oil probably is not an ideal situation. Adding a catch can to also capture and remove additional oil vapors that end up being added back to the combustion airflow that could also help reduce LSPI.
Things to consider
Pumps are not interchangeable but you'd think they were looking at them. Both are "2 stage" as in they're both variable geometry pumps. GM does reference the L84 as "single stage" but it's more marketing than anything else. In theory they're infinitely variable but GM only uses a binary high output and "low" output via the solenoid.Well I am not seeing this as the case. Maybe I have wrong, outdated information, but what I have been able to find does not confirm this.
Both engines have a variable displacement vane style oil pump, but the 6.2l appears to have a 2 stage oil flow control solenoid.
Site Maintenance
poweredsolutions.gm.com
I am having hard time finding the actual solenoid as a part number, but there are different part numbers for the oil pumps, not sure if this is due to the flow control solenoid or not?
The wiring pigtail for the oil flow control solenoid only shows up for the 6.2l, not the L84 5.3l, but does appear to fit the L83 5.3l engine
And for the L84 5.3l engine the oil pump part number is listed as GM Part # 12733671 and any real pictures I have found do not include the oil pump flow solenoid like the 6.2l.
For the L87 6.2l engine, the oil pump part number is listed as GM Part# 12733670
The earlier 5.3l L83 engines may have had a 2 stage oil pump, but I am not finding this on the current generation L84 engines.
I may be in fact wrong, but I have put a lot of time in researching this and maybe I missed something?
I am sure the crowd will correct me if I am wrong.
I have my 20 years tied up in the 6.0l, not spent much time with the newer 5.3l and 6.2l, just starting to get a grasp on these.
Not sure where you are getting information that LSPI isn't an issue with non forced induction engines. While there is a lot of info and discussion about LSPI on forced induction engines, mainly because the proliferation of smaller displacement 4 and 6 cylinder turbo applications, LSPI is also an issue on NA engines as well, especially depending on how the NA engine is used. Towing and/or hauling heavy loads being a primary example of situations where LSPI can be more severe and more damaging on a NA engine.LSPI really isn't an issue with atmospheric engines. Forced induction different story.
