Faulty oil pressure gauge?
ABN45
Wisconsin
So i have no check engine lights on and the oil pressure seems fine. With regular drive it's under half, but when I get on the gas it goes past half. All seems fine while driving. Doesn't bog down.
first pic is under half with regular driving, 2nd is getting on the gas.
Could it be a faulty gauge?
2012 GMC YUKON SLT/5.3
147 thousand miles.
Thanks yall
lspann3525
looks normal. when the engine is cold I get 40 psi while driving...once warm I get around 35 psi just cruising at slow speeds.. when accelerating it does suppose to increase according to the rpm
Also check your oil level make sure its good. There is also a pickup tube o-ring that can leak and cause the engine to have a hard time sucking oil thru the pickup tube. but usually when this happen youll get really low oil pressure and the oil pressure increases as the engine warms up
strutaeng
Dallas, Texas
Looks normal to me. It's going to vary with changes in temperature and RPM.
A few days ago I got a Ford Edge as a rental (Ecoboost engine, I suppose?). The only thing it showed on the cluster was speed and fuel level! I was like, "that's it?!" Lot's of other tech stuff tho, LOL.
I did discover that if you put it into "sport" mode, it enabled the tachometer. I then proceeded to pass cars like a mad man :cool:
ABN45
ABN45
Wisconsin
Ya you would put it in sport mode and abuse it, I like it,haha
Foggy
KS
Oil pressure rises with RPM.. So Totally Normal and within spec.
Drive On !! You've got it better than a lot folks
j91z28d1
so anyone else ever put a scanner on a LT? I know they have a variable displacement pump but I can't imagine they run the same oil pressure at all rpm.
are the new gauges just fancy looking lights or are they actually able to hold high oil pressure at idle? I'm guessing not, cause that would be highly inefficient fuel mileage wise.
but then again the new LT seems to get worse milage in the suv's than the old ls's even with direct injection and 10 speeds.
Foggy
KS
What do you mean better? I'm curious now.
Lots of people on the forum have had oil pressure issues. Whether it's
from oil pump Oring issues, cam bearings, DOD issues , leaking VLOM's
ETC ETC
Your oil "issue" is NOT an issue at all.... It's working exactly as designed...
SO for having a 10+ year vehicle you are fortunate to have a good one/ one that
has been taken care of.
ABN45
ABN45
Wisconsin
ETC ETC
Ahh ok. I gotcha on why I'm lucky now. Hell i even have a warranty the dealership thru in.
I was reading tho that the 2012 engine/tranny were a good year to have. Just what I read was all.
BadDaddy2003
