Exhaust rattle issue
draper11
I am getting what sounds like exhaust system vibration at certain levels of acceleration. Tonight, at 1200 rpm under light constant throttle, I almost got it to do it at intervals a few seconds apart. The RPM would lightly tick up as it occurred.
I did have a look under the truck this past weekend. I think the noise is the heat shield before the muffler. I put hose clamps around it which I think lessened the sound. I did not see any vibratory issues with 02 sensors.
Can I be getting some kind of misfire through the system? Do I have a cat issue or some other compromise? Do the rubber exhaust hangers get loose over time allowing excessive shake?
Thanks for any suggestions to look for next.
j91z28d1
I'm pretty badly at finding rattles but if you got a rubber mallet. you can climb under and tap the exhaust with it. you might find your rattle.
hit the cats too, it's possible the brick inside comes loose and rattles around.
rdezs
If you had a misfire or a defective catalytic converter, you'd get a check engine light. But yeah, I like the rubber mallet I keep hanging on the wall. Tap on the catalytic converter as well as the muffler and resonator if you have one. Could be just a baffle inside of the muffler came loose. Those big rubber hangers typically don't stretch out, but get harder with age. Heat shields are probably the number one rattle item..... Speaking of heat shields, check if you're exhaust manifolds have the heat shields on them. I've seen a couple of those come loose and vibrate depending on RPM
CTX-SLPR
College Station, TX
I'm having the same sounds and it turns out that the flexpipe just behind the rear most cat is broken (the outer braiding is swollen). Open the passenger door and start it to see if you get exhaust leak sounds as well.
D
draper11
That’s interesting. My braiding was swollen and loose- so I clamped it- how did you find that it was broken? I did remove the pipe to refit the connector. Is there another downstream before the muffler?
D
draper11
How did you figure out it was broken? My braiding seems to be the source of the noise.
CTX-SLPR
College Station, TX
I definitely have an exhaust leak in that location. Poking at it today while soaking the headpipe bolts and it might be the ball joint in front of the flexpipe as that is also a bit loose cold vs. my rattle comes on when it's at temperature mostly.
j91z28d1
there's been posts from others about that weird clamp leaking. I replaced mine and it still leaks some haha.
if your flex pipe is bad, an exhaust shop could replace it and that style clamp with something else. or just weld it solid
D
draper11
I looked at it again last night with a blower and soapy water. The coupling at the flex pipe is letting a bunch of flow through. Both manifold flanges were also blowing bubbles pretty good. I’m assuming I would get improvement by addressing these. I’m hoping I can drop the cats and easily replace donuts?
CTX-SLPR
College Station, TX
I'm dropping my headpipe(s) tomorrow to get to the trans TECHM, already started soaking the flange bolts with PB Blaster in hopes to get them off without stripping/breaking the studs. I'll try to keep a log of how it goes and what the flexpipe looks like once that's down.
D
draper11
I sprayed mine. I loosened one pretty easily with a wrench but another was tight. I Need to get a deep 15MM while they hydrate.
CTX-SLPR
College Station, TX
I ended up being able to get the nuts off without too much headache using an electric impact gun. The troublesome clamp I disassembled and cleaned out with sandpaper. Overall the inside of the flex pipe looked fine, the outside just had a flat section about 2-3in back which makes the braid look bulged.
As a cheap as free option I took the whole joint apart, used 120 grit sandpaper to get the crud off of all the mating and clamping surfaces AND most importantly made sure I shoved the tailpipe side firmly into the head pipe section while tightening the clamp bolt down.
Results on a cold start and 30min of test driving and idling messing with trans fluid and other things was no more exhaust leak sounds nor rattle. Tomorrow I’ll take it on an hour long drive to try to get the trans temp up and listen for the rattle that came in at ~35mph under light throttle but only after everything was at temp.
BadDaddy2003
