500 miles, = 1 qt oil
the blur
Cyber Space
2014 figured this wasn't a problem. But apparently I have stuck oil rings. Every week, qt of oil. Blows smoke out the exhaust at 4000 RPM's.
How difficult is the top end cleaner job on the passenger side, 2 rear plugs. The others look easy.
120,000 miles...
donjetman
Maybe try restore and protect made by Valvoline...
VRP is a good cleaning oil, but takes several full oil change intervals to clean things up.
For immediate unsticking of the piston rings do a piston & combustion chamber soak:
drain the oil and leave the plug out. I took all the sparkies out, squirted Motor Medic engine flush by Gunk(AutoZone) in the plug holes, You can get a turkey baster or large syringe(tractor supply) and let it soak in the combustion chambers for hrs, then put a socket and breaker bar on the harmonic balancer bolt, then wiggled it back and forth, then repeat. I did this several times over a whole weekend. Anything that gets by the rings will drain out.
Before putting the sparkies back in, I spun the engine over a lot with the starter to get it all the Motor Medic out of the combustion chambers.
Re-fill with oil. Drive it for 500 miles. Then do an oil and filter change with the best $$ can buy, and hopefully you'll have great results like me.
T
the blur
Cyber Space
I have been using Pennzoil ultra syn natural gas 5w-30 for ever. Might be time to move away, but seeming this is such a common problem... I can't really blame the oil. I did order the VRP from amazon. definitely worth a try before the top engine cleaner job.
I looked that oil up and it ain't Dexos1 Gen 2 certified. That's the kind of oil GM spec'd to run in your motor and you chose something else.
This is what you want if you wish to stick with Pennzoil:
This is what GM currently specs for your LS engines:
Compare the stats, the ASTM stats, and see how yours match up or don't.
B-train
One thing to add......remember to unplug the harness on each valve cover to disable the fuel injectors/coils. I did something similar with GM top engine cleaner. Went to spin it over and blow the gunk out and promptly started the engine bay on fire......Let me tell you, pig mats and the sound deadening on the hood AREN'T flame resistant. LOL.
If I had been working on it outside, I may have let it burn (problem child 2009 Denali). But, being in my shop I grabbed the 5 gallon dog water bucket and gave it a splash.
T
the blur
Cyber Space
I am starting with V-R&P. Did the oil change last night. We'll see how it goes. Make a science experiment out of it. I can't do the top engine cleaner until it gets warmer outside...
donjetman
I'm recently put a load of Val R&P in my 233k mile Toyota FJ. I did it for the Protect, not for the Restore (zero oil consumption).
In our 6.2 Denali I'm running a 33%mix of VPB"Restore" & 67% M1. I'm still trying to clean its guts up. Next year I'll probably switch it to HPL PPCEO 5w30 which is one step above the HPL PCEO I'm running in my easy on oil LS1 C5.
tom3
These low tension thin metric ring packs are great, until they aren't. With today's super detergent oils I'm really surprised to see this problem.
opfor2
Riverside County, CA
Wow, $ 12.57 a quart for ACDelco 5w30 motor oil??
j91z28d1
I believe it's more the lack of old school pvc valves sucking I tons of oil into the intake because of high air flow at idle. we never really had this problem in the older ls1s that had pvc valves. my 02 camaro I had and my buddy that had a 01 c5 never have oil issues. my 08 c6 without a valve even with the lifter valley source that should have less oil would drink a half a qt a day in hard driving before pvc mods. even the upgraded baffle in the valve cover isn't all that great. my 2011 intake was full of oil when I had it off. I let it drain till I got bored. still had some in it. that and the afm cylinder not burning it. you just get tons of build up on these pistons.
my cheap catch can catches a decent amount of oil still.
Where are you getting that pricing? I've never paid that or anywhere close to it myself.
It's the 3rd Amazon link you posted in #6 of this thread:
j91z28d1
if you buy oil by the qt it's all expensive. some of the liquid moly brand is well over 15$ a qt.
by the gal or those 5qt jugs is the only way. which of course is annoying when our trucks take almost 6 qt haha.
Oh! LOL
I've either bought it from a local ACDelco store or from Rock Auto myself. Prices kept going up so that's when I sought out an alternative and Quaker State was tested to be just as good for my purposes. If my memory wasn't so bad, I would have just listened to Pete years ago! LOL
T
the blur
Cyber Space
Some guy on you tube drilled oil return holes in the pistons. Not that I'm pulling my motor, .... craigslist time for truck.
AdrienR
