Saved from scrap
D
Dan2002
How much of a difference between #7 and others that are showing misfires? You may have narrowed it down to #7 and that would be a big help in figuring out what is going on. First I would suspect the wire. Swap with another and see if the misfire moves too. Then if that doesnt change anything, put it all back original and swap coils and see if that moves the problem to another cylinder. If no change after wire and coil change then you are down to the spark plug, coil wiring harness, output of PCM to fire coils and then the valvetrain and rings of the #7 cylinder. That would need a compression check to see where you are at there and at that time all 8 cylinders would need to be checked to see how #7 looks in comparison.
Ive chased my rear many times over a bad spark plug wire that visibly looks fine but in the dark you can usually see the lightning jump from them to ground depending on where the flaw in the wire is. So at night start it up and with hood raised have a look at #7 to see if you see a light show, also listen closely for a snapping sound. Keep your hands in your pockets so you dont get in the fan or find the lightning the hard way....with your hand. A coil with a cracked housing can do the same and the lightning will jump out to ground (metal) and it will make a snapping sound also. Ignition voltage is over 20kv so dont find out the hard way! Itll make you pee yourself!
update,
after having a few weeks or rain and being very busy at work, today i finally had the day off. i been outside since this morning,
i started by switching, the spark plug, coil and wire cable from a good cylinder to the 7 cylinder, but the misfire condition didnt change,
next i did a compression test, and its good at 150psi.
next i did a cylinder leak down test. and the pressure on cylinder hold, so valves are fine.
now i am thinking on whats next??
i did forget to swap the fuel injector but i dont think thats the issue.
update,
do a backpressure test
D
Dan2002
update,
Here's a video, live data while vehicle in idle
Donal
Americus Georgia
Are these injectors still in the your engine?
"Got a set of injectors on Amazon (prime) so I could get them quick,"
Be careful when buying parts on Amazon. Lots of counterfeit ("inexpensive") parts. You get what you pay for.
For now, swap the injector with another cylinder to see if the misfire follows (as @Mudsport96 recommends). That way you'll know if it's the cause. Don't introduce new parts until you can determine one is bad.
D
Dan2002
i will do that tomorrow mornig. thank you
D
Dan2002
How did it go?
i feel dumb, i switch number 7 injector to the number one which is not misfiring, put it all together and started the car, still flashing check engine, scanned it and only code says p0300 random misfire detected.
did live data and turns out number one is now misfiring and number 7 is no longer misfiring o_O
S33k3r
Dallas, Texas
Why the hell do you feel dumb? If not every single member of this forum, I'd bet a huge majority learned from something like this. And I would posit none of them is dumb. Think of it this way: How do you know what you don't know? You learn it from people who do know. And you are blessed with a forum where people actually care about the members knowing.
Amen.
TollKeeper
Brighton, CO
If these are OEM injectors, this is a hell of a deal...
Can someone take a look and verify?
The price tells it all. No way they're Genuine GM @ $10 each.
Aquamania001
This past weekend I saved a 2003 Cadillac Escalade from being scrapped.
It did cost me a lot because I bought it from the scrap guy. He was going to part it out.
But I had to save it because it's one of the cleanest Escalade I have seen. And 0 rust,
The guy just told me that the engine had a skip. After checking it out for a couple of days, I managed to pull a code p0300 which is random misfire
Which is about 5 cylinders that have misfire when its running.
Today I checked fuel pressure and it's at 49-50 psi with the engine running, is that normal or does it need to be higher
Good on you for saving that truck!!! Thanks for giving it a few more years of life. Now enjoy it and have a good time on road trips!!!
CrackerJack135
