Saved from scrap
rockola1971
Indiana (formerly IL)
Update..!!
Got a set of injectors on Amazon (prime) so I could get them quick,and cheap and installed them today.
Most of the misfiring cylinders are not misfiring anymore, I have my scanner which shows each cylinder, how many misfires it generates. I have only 2 cylinders on bank2 that are misfiring a little bit. And one cylinder on bank1 that is also misfiring a little. Bit
I believe those little misfires are due to the bad spark plugs because they were dark when I checked compression.
Now im about to order, new coils ,new cables,new spark plugs and new injectors, maybe a good name brand
Judging by your compression numbers, your plugs are trashed from blow by. Spray some oil in each cylinder (cold engine) and see if compression comes up. If it does substantially then your rings are shot. If it doesnt then you have valve sealing problems.
D
Dan2002
i got new ac delco spark plugs, new NGK coils, new wires, and set of new ULTRA-POWER injectors. ac delco injectors were out of stock on rockauto
after installing all. i still get the p0300 engine light flashing on the dash. engine sounds a little better,
after watching live data for misfiring cylinders i can see number 1 and number 7 cylinder misfiring but mostly number 7.
anything else i should check ??
It's flashing? I had a flashing p0300 in my van while driving, one of the issues I found was a clogged cat. It had 3. Have you checked those yet?
D
Dan2002
no i have not checked for clogged cat, but will do tomorrow , thank you
D
Dan2002
Update..
so i ran the truck for about 20 minutes down small roads. after i got home i checked each catalytic converter with my laser termometer.
passangers side seems to be evently heated at 230f to 255F
then went to the drivers side and the upper side closer to the engine was normal 235F
but the rear of the catalityc was over 600F and i could actually see the catalytic converter glow red '
Sparksalot
Bastrop County, Texas
Update..
rockola1971
Update..
Well that settles that. :cool: Someone installed a glow in the dark cat but didnt replace the other one with the same.
tom3
Seems like the misfiring cylinders would cause the overheated converter? Or would the converter cause the cylinders to misfire? Let us know how this turns out.
backpressure test is what determines it ultimately, on mine it should have 2.5psi max but was reading 5psi at idle and 10psi when throttled up
TollKeeper
Brighton, CO
My last car that made the converters glow red, it was not the converters, but the ECM Driver was double pulsing the injectors, once when it was supposed to, and once 180* out, so it was dumping raw fuel into the exhaust.
Replaced the ECM, and that solved the problem... And increased my fuel mileage!
D
Dan2002
nders would cause the overheated converter? Or would the converter cause the cylinders to misfire? Let us know how this turns-----------
well, after new converters , it is still giving me code p0300. o_O
any ideas whats the next step i should take?
new plugs and wires
new coils.
new fuel injectors
new cats
new all 02 sensors
D
Dan2002
Did you clear all codes after installing cats?
yes all codes cleared before starting the vehicle, then i started the vehicle and no lights were on but it wasnt running smooth, so when i attempted to acelerate the check engine light cames on flashing, and gives out code p0300 only code.
rockola1971
Flashing check engine light means active spark knock. You need to get a scanner on that top see which cylinder(s) are knocking. Could be bad knock sensors or their harness or a bunch of other things. Need to see if we can get it narrowed down to certain cylinders only or all cylinders.
D
Dan2002
yes, i have already seen with my scanner and live data.
i see number 7 cylinder misfiring the most
drdave81
Waterford, MI
No a flashing check engine light means you have a catalyst damaging misfire. Basically you are sending raw fuel right into the cats. That's why the one was glowing. OP fixed a symptom, not a cause.
You need to figure out why you have no spark, or not adequate enough spark to properly light the air/fuel mixture in the cylinder.
rockola1971
How much of a difference between #7 and others that are showing misfires? You may have narrowed it down to #7 and that would be a big help in figuring out what is going on. First I would suspect the wire. Swap with another and see if the misfire moves too. Then if that doesnt change anything, put it all back original and swap coils and see if that moves the problem to another cylinder. If no change after wire and coil change then you are down to the spark plug, coil wiring harness, output of PCM to fire coils and then the valvetrain and rings of the #7 cylinder. That would need a compression check to see where you are at there and at that time all 8 cylinders would need to be checked to see how #7 looks in comparison.
Ive chased my rear many times over a bad spark plug wire that visibly looks fine but in the dark you can usually see the lightning jump from them to ground depending on where the flaw in the wire is. So at night start it up and with hood raised have a look at #7 to see if you see a light show, also listen closely for a snapping sound. Keep your hands in your pockets so you dont get in the fan or find the lightning the hard way....with your hand. A coil with a cracked housing can do the same and the lightning will jump out to ground (metal) and it will make a snapping sound also. Ignition voltage is over 20kv so dont find out the hard way! Itll make you pee yourself!
HeavyHoe03
