2019 Yukon Key Fob Range Blows...What Would You Do?
arcycle4fun
I just completed this repair on my 2019 GMC Yukon XL. I was about ready to sell the vehicle to stop having to deal with the very poor remote range. Dealer quoted me $750 for an "attempted fix" and this $21 part did the trick. I went from 0-10' of range, to hundreds of feet. Everything works fantastically.
The one thing that took me some extra effort, since I didn't have much experience removing trim, was there weren't any good guides online on how to remove the trim. I didn't realize how much force was needed to pop the trim off, but once I finally was able to see the tabs more clearly, I made the strong effort to get it unsnapped.
The key was to get the piece off and out from under the longer headliner holding piece across the headliner. That allowed me to pull back the pillar piece enough to see how it was mounted around the speaker. I removed that, partially popped back the headliner and was able to get in and remove the old antenna with a socket extension.
Thanks again, this is a game changer.
bsmith45
No need to take entire headliner down. I changed mine myself in 20 min. It’s 20 dollar part. Just need to take some side panels off to lower the back corner of headliner. If you have a burn or xl I think just the back pillar panel needs to come off given there is more play in the headliner.
Hi Bob,
I know this post is 3 years old but Im hoping to get some advice. I am having the same issue in my 2018 Tahoe and I wanted to ask how you get the panels off without breaking anything? Is there a specific tool I need or just careful force to release the clips?
CMoore711
Dalien
Does the antenna need to be programmed by the dealer or is it just a matter of plugging it in? My dealer told me that it needs to be programmed to my vehicle.
Jroby42
Mine worked by plugging in, did not require dealer at all.
Dalien
I'm confused?? I went to the dealer to get a replacement Receiver / Antenna for my 2018 Yukon XL. The dealer sold me the 315 Mhz antenna part # 1358-6853. I went on Rock Auto and it lists the same part for my vehicle. Whats confusing is that the dealer showed me that the antenna is located on the passenger side rear pillar (3rd pillar). I was looking at Nickfire20's post which shows it under the roof liner with a short wire coming off the antenna and plugging onto the side window wires. My vehicle has the same wire coming out from the roof liner. The antenna that the dealer sold me does not look the same as the one in Nickfire20's post. Do I have the right part?? I haven't taken the panelling off yet so I guess it's possible that it is located on the pillar and the wire that is attached to the side window is long and plugs into the antenna I bought. The dealer and Rock Auto both say that the antenna needs to be programmed but other posts on this site say that they plugged it in and it worked. Any clarification would be greatly appreciated.
Thanks!
PG01
Up here to the right
Oh yeah, did this a few months ago too…. Wife is very happy that she doesn’t have be 3’ from the truck to lock/unlock now.
nelsonto
Does anyone know if this will fix the issue I am having with my 2019 Yukon where the key fobs stop working (even though they have new batteries and the dealer has reprogrammed them on multiple occasions). When shutting off the car, it hesitates for a few seconds, shuts the car down, and then states on the Display “Remote not Detected, Press Brake to Restart”. From then on neither fob works inside or outside of the vehicle and will not operate the locks or anything. After a few hours the first fob will start to work but the second one never works without reprogramming. Every few days this happens.
StinkyLinky8
Bucks County, Pennsylvania
I was having that same issue intermittently. Replacing the radio receiver fixed every key fob related issue I had. Took maybe a half hour to do and I’m more annoyed that I waited so long to fix it.
bdhfarmboy
HA! My range blew on my 2020 Yukon and I just finished replacing mine. I was a good 300-400 yards or more away before it stopped working. So the question I have, you see that little button? It came off while I was replacing that sensor. How do I stick it back to the glass?
I know this is an old thread, and probably a long shot, but any recommendations on how to reattached the button. When changing the amplifier in my 2019 Yukon, I accidentally popped one of the buttons off. Interestingly enough, the radio still works with the amplifier detached but want to reattached without screwing up the reception.
StinkyLinky8
My wife’s jeep defroster button/connector broke off and I was able to fix it on the driveway with “Solder-it” paste and a smaller torch. You can probably to it with a soldering iron being close to the headliner.
Solder it paste
Timothy Sargent
I have a 2018 Yukon Denali non-XL... Anyone know which part # to order from Rock Auto?
Munsterlander
What I did (2018 Yukon SLT, not Denali) was pull enough trim pieces to stick my phone in there and take a photo of the part number on the existing amp, then ordered the one that it (your screenshot from Rock Auto for example) says to replace it with. I ended up ordering it from Amazon as it was much faster.
Also, to add to the collective knowledge, my only symptom was that the buttons on the door handles got to the point that only very seldom would they unlock the doors. I had to remove the fob from my pocket and unlock the doors with the fob button. (But I never use the remote start, so don't know if that was an issue or not.) The replacement amp seems to have fixed by door handle button problem!
tecman
Thank you all for this thread! I replaced my antenna a couple weeks ago and it works great on my 2018 Yukon Denali. Picture is the original part replaced with GM# 84693389
jph4387
Sorry to revive an old thread but I'm doing this repair to my Yukon tomorrow. For those that did it, I have a question. The triangle-ish shaped receiver that is attached to the amplifier, how did you get the old one off the glass, i.e. detach it? I don't want to damage the glass. Did you pry it off, use heat, etc.?
slupie
Bartlett, IL
It just snaps on. Use a platic pry tool to snap it off. The antenna stays on the glass.
jph4387
Thanks slupie. I just got it switched over. My range is far better but still didn't fix my problem :(.
JasonW4141
