89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Yeah, when I get some free time I'll pull mine. The half shafts are out, and when I spun the driver's side of the front diff it's gritty/crunchy.
What did you tie the front driveshaft to?
I removed the front drive shaft. Trying to make room to access the engine for engine oil pan replacement access and worst case engine replacement.
89Suburban
SE PA
Here is a pic
Charlie207
LFOD, New Hampshire
......and just bought a new torque converter to throw in the 180k 6L80 while the engine is out.
Link to VEGE (CVC) BU60FHD.
Precision of New Hampton (the blue TC people) are dumb, and won't sell to individuals, so I tossed my $$$ to Summit. It's 2024... set up an online marketplace.
Grady_Wilson
Wyoming
All done.
This old man is about to have a heat stroke.
The few instances like this a year is when I miss having a pool.
Rinse off and then dive in and feel the heat get sucked out of your body.
I'll be taking it for a ride after I hit a cool shower and rest for a bit.
Need to pick up a trailer harness adapter and some groceries.
RooTBeeRthe1st
Was stuck crawling up a hill in traffic on the way home yesterday. IATs didn't like that. Was only 103 yesterday.
Then they settled back down after we actually got rolling again.
I bet those hood lovers would have really helped.
Sparksalot
Bastrop County, Texas
I bet those good lovers would have really helped.
I used to see numbers like that or higher in thecopcar. the louvers were a massive help.
Charlie207
LFOD, New Hampshire
I'm sure someone has posted it before, but how do you get those informations to display on the dashboard?
mikez71
AutoSync and HPTuners are my two favorite upgrades!
(and my chime bypass..)
Although I have no drivetrain upgrades to compare to.. apples/oranges kinda thing..
St. Louis
That's neat, but $$$. I would like the windows functions that have been standard in cars from over 20 years ago. (all windows down with remote, auto-up, etc...)
Not all cars 20+ years old have those standard. Our 2015 Acadia has auto up but no remote functions. Only cars I know that old that had remote window functions was with aftermarket alarm systems.
It does much, much more and also has the ability to flash the BCM.
I like it mostly for the ability to disable the TPMS system and have no warning lights on dash due to dead sensors.
Also can disable AFM
Read and clear trouble codes
Program key fobs
mikez71
additional favorite Autosync functions
disable auto door locks!
remote unlock all doors (1 press)
remote open/close windows
retained accessory power (I can still close my windows after opening the door!)
manual exit lighting (flash high beams after door is open)
custom approach/exit lighting (park/rev/high/low/fog)
other lighting customizations (timeouts, brightness, etc)
disable auto headlamps
favorites I never use
manual high idle
emergency flashers
extend remote start run time (10min -> 20 min)
Charlie207
LFOD, New Hampshire
Program key fobs
My old Nissans, Saabs, and BMWs could all lower windows with the factory remote, as some examples. GM is forever behind on common-sense.
Drewphil
