Crankshaft position sensor went bad can it get me home?
Tonyv__
Bucks county PA
Will replacing the crank sensor require a relearn?
Yes but can be driven without the relearn
edit. Maybe not iirc I don’t think my CKP not learned code showed up until I replaced the ECM. But even when the code was present, i was able to drive it until I did the learn
skpyle
Senior Member
Starter
CKP after wiggling starter out of the way.
When I did mine, the starter put up a fight. There is very little wiggle room, and you have to hold your mouth just right to get the starter to move where you want it to. As well, remove the plastic dust shield around where the starter enters the bellhousing for necessary access.
Good Luck!
T
Trey Hardy
Starter
Good Luck!
Thank you!
Drewphil
