Yukon Denali amplifier speaker stereo upgrade
kerlyb
So I found a pretty decent solution. Try replacing your dash tweeters with the kicker ksc270s, and dont do anything else. They run about $65. Report back what you find...
I assume this upgrade should also work in Tahoe HC w/ Bose???
K2 Kaiju
The Depths
It should work with any K2 Bose setup (including LT and SLT) since they all have the cheap ass corners. Please try it out and let us know what you think...
Thrust
ICT
Are the D pillar speakers the same as the dash?
Would it be worth replacing them?
Thrust
ICT
Another added perk of this mod, the seat belt chime coming from the bose speakers was almost unbearable to me. Very loud to the point of obnoxious.
Now with the Kicker speakers the noise is more normal level and not so harsh. Anyone else notice this?
kerlyb
Replaced corner dash speakers with the Kickers w/ bass blocker as suggested. No sound from the Kickers. Double checked my connections and polarity and still no sound. Every other Bose speaker in SUV works fine except these Kickers. Reinstalled OEM Bose speakers and still no sound from the dash speakers. Crutchfield support suggested checking factory speaker wires/harness with multimeter. Will do so when I can get a hold of a multimeter.
In the mean time, any other suggestions?
Jroby42
Sorry to hear about the sound issue, I just installed mine this week. Crutchfield had them on sale for $48, everything is great! How did you connect the Kickers? Crimp, posi-lock, sautered, etc.
kerlyb
Yep I got same deal from Crutchfield. Connected the bass blockers to the positive side using the wire connectors that came with it. Then used the Metra 72-4573 GM speaker wiring harness to connect to speaker connections.
Jroby42
Interesting connector, I used posi-locks and aside from getting my hands in there to strip wire and connect, it wasn't bad. Confirming the oem tweeters were working prior? All fuses look good? Disconnect negative terminal on battery to see if the system "resets"?
kerlyb
Yes OEM speakers worked prior to swap out, fuses good, and even tried infortainment reset....and still no sound.
Interesting thing just happened now. I decided to put everything back to stock and have car audio shop fix it. I reinstalled OEM Bose speakers and surprise surprise...the Bose speakers were working again. With radio on and music still playing, I quickly replaced with Kicker speakers and sound was finally coming from both Kickers. Thinking everything was fixed and OK, I started to put speaker grille and pillar trim back on. Radio power timed out and then shut off. I restarted the radio....no more sound from the Kickers. WTF???
gtrslngrchris
FWIW I recently tried the Kicker upgrade in the front corners and I noticed in the Bose module it had DTCs for channel 7 and 8, presumably because now there wasn't enough resistance for it to recognize the speakers being there. Luckily I have not had any functional issues but the DTCs did appear so who knows :shrug:
K2 Kaiju
The Depths
Is there any exposed wire thats touching metal getting grounded? Could be cross wired or a bad batch from factory. Mine have been excellent - just did a 800 mile journey with my son to do his college orientation. I will say his music is much more "bass-centric" than mine and he commented about the quality of thump. Its all about those little resistors...
SeaMonster3581
Plug n play mostly, but you do need to connect the wires. My speakers came with crimp connectors, or you could solder them - I actually used a new type of connector (shrink wrap meets solder) that just needs a lighter or heat gun.
As for the speakers, they arent much - very small and 4 ohm - but they have a heavier magnet plus little inline crossovers you attach to positive side. It fixes where Bose screwed up - like a cheat code. The factory corners get a full range signal but cant do any low range so they sound like shit and dominate the stage with harsh treble. By replacing them, every other speaker gets more power. Its exactly what most people expect in a Denali - much clearer sound with more bass. Not going to win competitions, but your music will sound much better.
If you want to add an amp, speakers and sub, you will be much louder, but you will also need to process the signal to balance the sound, and know what your doing. If you want people to hear you blocks away, this is the way. $1k+ vs $65 and all day vs an hour...
I have a 2007 Denali Yukon. Could this work for mine as well? Those are the speakers that sit on the side parts on each side of the windshield right?
SeaMonster3581
I have been wondering what to do for mine as well. But whoever had it before me swapped the front door speakers with JBL DSP idk what the exact numbers are I just know they’re DSP but if they did swap all six of the speakers along the doors and D Panels. Would it be smart to just keep those in?
RoadTrip
FL & MN
Look up the specs on the JBL speakers to see if they are 4-ohm rated.
You will want to make sure all of the speakers in your system have the same rating.
Make sure the JBLs have no tears in the cone or support and that they move freely by hand with no scratching in the voice coil.
jkhuntzinger
