Change their diet. Who had to make that stressful call to you?Drove it to work only to find out my cats are clogged
Salt on roads does that.Went to investigating my exhaust leak and got a look at my spare, yikeshit it with PB blaster real good and I’ll get back to fiddling next weekend View attachment 422255View attachment 422256
Combined with not one iota of maintenance smh. I’m fully expecting everything to break when I get to fiddling, been about 90k miles since I last, or someone I should say, touched it.Salt on roads does that.
Check the tire pressure! LolWent to investigating my exhaust leak and got a look at my spare, yikeshit it with PB blaster real good and I’ll get back to fiddling next weekend View attachment 422255View attachment 422256
The way that lip is rusted I’ve already started sourcing a replacement rim for my replacement tire.Check the tire pressure! Lol
You can see one jack stand on the passenger side of the pic.Hope you had more support under there than the one visible jack.
You definitely lucked out with the removal.Had her up in the air yesterday. View attachment 422340
Steering idler had been on the way out for sometime but hadn't worked out where the movement was.
wasnt hard to get out and arm was an easy split.
Replaced with an AC Delco supreme fro R.A Am impressed with DHL yet again. Got it over here to New Zealand in No Time!!
Yes I sure did luck out!You definitely lucked out with the removal.
Yes had 2 axle stands left and right under the jack points on the frame.Hope you had more support under there than the one visible jack.
