The DOD tick finally got to me
Los Angeles, CA
So after 180,000 of religiously changing my oil at the 50% life marker the lifters are looking like they are going bad and i am sure the camshaft is getting scored.
SO Its time to start looking for a cam and rockers that will be necessary for the DOD delete.
I don't know if I want to keep the truck as stock as it is or go with a mild stage 2 that does not need any major reprogramming and tuning.
So can any of you point me in some directions or threads to see if I can figure out a good build. like for example can I use a corvette/camaro cam with LS7 lifters and springs?
as I look at aftermarket brands, the more I research, the more overwhelmed I get with options.
Any help will be greatly appreciated, thanks.
Trey Hardy
Texas speed dod delete kit
ls7 lifters and springs
And their stage 2 truck cam
You’ll be happy with it and it won’t be too too much probably around 1000$ maybe 1500$ if you get arp hardware all new gaskets and pushrods etc
Fernando Escobar
Los Angeles, CA
thanks been looking at their products and it seems like most cams you need to delete VVT. wasnt looking to going that route but i guess I might have too.
j91z28d1
there's a ton of posts around here about stock cams without afm but with vvt. they are out there.
what's it doing? random tick, constant tick? if it's random, you. right catch when it's not ticking and turn it off in the tune.. you'll need to turn it off in the turn anyways when you swap cams.
Fernando Escobar
Los Angeles, CA
At first i thought it was an exhaust tick. Then realized it was probably the lifters. After our annual roadtrip to Mexico (Guadalajara) its gotten worse. And one day i did the remote start and it almost sounded like it was grinding. So its time to get ready for the rebuild. Im on the fence about still about a regular camshaft vs a a stage 1-2. Nothing wrong with a little more umph!
But most kits a see on line have vvt deleted. Good thing i know what I am doing... Except for the tune, i need to outsorce that
The options are almost too many to count. Your first decision is to pick a course of action AND STICK TO IT. Switching up halfway through it often costs a lot more in money, but always in more time.
At 200,000 miles, I set out to delete mine with a stock non-AFM cam. I had all the parts and AFM was already turned off in the tune. It would've been exactly as it was before, but with no AFM and no special tuning needed, costing me about $600 all-in (pre-2020 prices on GM OEM parts). A friend offered me a deal too good to pass on a TSP Stage 2 and I jumped on it. With that brought a couple thousand dollars more in mods to support that cam in all reasonable manners, including a torque converter and custom tune. I have NO regrets and use the hell out of the package. My project starts here. It's a lot but should be very relevant and comprehensive for you.
Decide on what you wanna do and then we can help to narrow down your options. I will say that, since yours has VVT, it must be a 2010+, meaning it'd have the 6L80E. Unless it's been addressed already, I'd strongly suggest factoring an upgraded torque converter into the budget, even if keeping your engine stock, but especially if upgrading the cam.
If you get a SENSIBLE performance cam that deletes VVT and an appropriate converter, you won't sacrifice any low-end.
petethepug
Michael
SoCal
I just added this post to another thread. It fits just right here too …
You’re overthinking this. Grab an 08+ 6.0 motor from a 1/2 or 3/4 ton truck. They’re plug n play and only require the existing BCU to be re-tuned so the AFM/DOD is tuned out.
Low price, low effort, increased hp/tq, retains Reg fuel and it’s a factory No AFM/DOD motor dream swap.
Fernando Escobar
Los Angeles, CA
thanks your post has been a good read so far. I might take some ideas from you.
Dustin Jackson
@Marky Dissod I have been looking all morning and I wasn't able to find one with the same lobe profile as the L33 cam that also has VVT, I wonder if someone else would know
Fernando Escobar
Los Angeles, CA
some of those VVT cams are there but hard to find I guess. I need to fix my Truck ASAP so as much as I want to research and get a nice cam with good functions I guess I'm am going with the TSP package and the LS9 camshaft and lS7 springs they say everything is in stock so lets get this done and find a tuner. I have a friend that owns a place but im afraid he will want to tune it for the track and not the street lol
Marky Dissod
Are you super- or turbo-charging the engine?
If not, who suggested the LS9 camshaft to you?
Ask them why, before the LS9 camshaft disappoints you with soggy response under 3500RpM.
I wouldn't be surprised if you were better off with the Gen3 non-VVT L33 cam.
Fernando Escobar
Los Angeles, CA
When I look up their packages its one of the options from GM item #28-12638427. I thought I read that, not looking to supercharge the supermarket go getter lol but wanted a little umph that the basic no thrills cam.
On top of that I need to fix my car with the quickness and some other made cams will take time. I thought I had seen an ls7 option but I guess I was mistaken.
Geotrash
Dave
Richmond, VA
Which year, model and engine are we talking about here? I didn't see it yet in this thread.
I'm running a Cam Motion Stage 2 Truck Cam in my 2012 6.2L and I love it. Lots of grunt and great for towing, but no VVT. They sell the whole kit and caboodle also like TSP does and they also make the same cam in a grind specific for the 5.3.
My build thread is here and contains some notes on the job that will hopefully save you some time.
Fernando Escobar
Los Angeles, CA
Sorry Its a 2013 Yukon XL Denali
6.2 Engine AWD
Fernando Escobar
Los Angeles, CA
that cam motion option looks nice but it takes like 4 weeks to get which is of putting when you need to fix it asap. My folks will fly in soon and take my daily beater with them and don't want to drive my truck knowing I can damage more internals as it is. but it looks tempting for sure thanks.
donjetman
Fernando Escobar
Los Angeles, CA
Conedaddy
