Is better on-road handling possible without losing Z71's off-road capability?
Marky Dissod
No longer interested in either lowering or raising it.
Recently did GMT900 front brake upgrade. The braking performance improvement has reduced my fear of driving it considerably.
However, the thought of emergency lane changes still make me somewhere between nervous and uncomfortable.
(Majority of my driving experience has been accrued driving mid '90s Caprice 9C1s with LT1s.)
While upgrading the front brakes, my mech and I noticed the following things need maintaining (by maintaining, I mean UPGRADING; see front brake upgrade):
#1: Front jounce cushions disintegrated / pulverized. Can a Tahoe's front jounce cushions be upgraded with those from a Suburban, maybe a 2500?
If not, what other reasonably priced possibilities are there?
#2: All four shock dampers have rusted off nearly all of their red paint, one looks like it's just begun leaking a wee lil bit.
Are there Bilstein shock dampers available? Anything else considered a good bang for the buck in terms of longevity / durability?
#3: What swaybar upgrades are available? I know the improvements here can be considerable.
(#4: No immediates concern for either front torsion or rear coil springs, for now ...)
My hope / goal is better on-road handling, while preserving most of if not all of the Z71's inherent off-road prowess.
the jounce stops/bumb stops are easily replaceable
hellwig makes solid sway bars and those help a lot (front & rear)
some sport tires help also, offroad/all terrain or junk tires get you nothing but spun out or in a ditch, unless you live where there is snow or have some other reason then you don't need them
bilsteins are good 5100's or 4600's for the front & rear UNLESS you have the nivomats (self-leveling) on the back those are unmatched.
I run the goodyear eagle sport a/s, couldn't be happier
Z71 won't have the Nivomat shocks in the back; those are for the Premium Smooth Ride. If you need to convince yourself, look at your RPO codes and see that G65 is missing.
M
Marky Dissod
No G65.
So far, I'm thinking:
#1: Still looking for jounce cushion upgrades
#2: Bilstein 5100
#3: Hellwig or Nolathane swaybars (assuming that Nolathane kit works for GMT800?)
No G65.
#2: Bilstein 5100
Oops--thought you had a gmt900. I have the Hellwigs and love them.
M
Marky Dissod
Only piece of a GMT900 that interests me as of now, is the central seat.
With the center console storage compartment / cassette player gone, there's now room for it between the front seats.
Back to the suspension, still have some questions:
#1: Is there such a thing as an upgrade beyond OE for the front jounce cushions?
#2: Is the Bilstein 5100 a wise choice if I am NOT lifting my Z71?
#3: Are there any other RESPECTED swaybar options besides Hellwig or Nolathane?
I'm thinking that stiffer sway bars -- or just stiffening the suspension as a whole -- might negatively impact the off-road suspension response. Now I'm not sure how much or what type of off-roading you do, but the tradeoff is something to consider.
M
Marky Dissod
So far, the limit of my off-roading has been limited to using 4Hi in winter conditions where FWD & RWD vehicles are stopped and stuck, and AWD vehicles are slowed but not stopped.
The next tires I buy will be selected prioritizing their capabilities in rain snow and ice over mud & dirt.
Hellwig front and rear sway bars, if they are available for GMT800. The improvement in handling is substantial.
No G65.
#2: Bilstein 5100
in regards to the bump stops you could maybe get neoprene, but the stops do not do much if anything in regards to handling
the 5100's are fine
Hellwig is pretty much top of the food chain, if there was something better I would be using them unless of course they cost some stupid amount of money.
tires are going to be the hardest decision and you might find that even the best rated tires can be total crap, the issue there is cost because if you do not like the tires then you are out a chunk of money as usually once they are installed they are yours unless there is a defect
this means reading a LOT of reviews
M
Marky Dissod
tires are going to be the hardest decision ... might find that even the best rated tires can be total crap ... if you do not like the tires then you are out a chunk of money as usually, once they are installed they are yours unless there is a defect - this means reading a LOT of reviews
So far, only Tire Rack SEEMS to have trustworthy reviews.
Are there any other tire vendors with trustworthy tire reviews or ratings?
blackelky
Simple tire is great they shipped right to my dealer and only 20$ a tire balanced and mounted. Falkens wildpeaks, toyo at2s or 3s, michelin, pirelli scorpion if you need all terrains. Yokohamas are good too. Coopers have been trash for me in the passed and stay away from all the offbrands. Some have had good luck with those offbrands but i won't risk it personally.
M
Marky Dissod
Coopers have been trash for me in the past; stay away from all the offbrands.
Never heard or read enough good things about any type of Cooper tire to consider them.
As for the off-brands ...
I wish I actually knew the offbrands' real affiliations.
They're much tougher to decipher than that Maserati that looked an awful lot like a Chrysler K-car because it actually was one.
Sparksalot
Bastrop County, Texas
Cooper used to be a very good tire. They were bought out by Goodyear I believe, a few years ago. I’ve heard nothing positive since that.
Davidj281
I second the Hellwig swaybars. Awesome. Get them and the Spohn front sway bar links.
Spohn lower control arms and canard bars help also.
pretty much any site is going to put the best reviews first, but you have to read the bad as well, be sure to read the full spectrum 5 stars, 1 star and everything in between.
sometimes the same tire is used on a small car and on suv's, the desired performance can differ between the two
most sites do not differentiate reviews between sizes and only the model and sometimes only the brand
a 18" tire and a 24" tire are going to be completely different performance wise.
some tires are hard, some are medium and some are soft. rated mileage will be more with a hard tire and less with a soft tire.
grip will be different as well. a medium hardness tire will have the best grip, soft tires wear quickly, have less grip and may even bend out of shape in a turn, hard tires have the best mileage but less grip
load ratings are different across the board, I would look at what the oem tire load rating is and try to match it or beat it
some tires now have a new classification instead of m/s it might be mountain peaks
it's a mess and I wouldn't rule out offbrands some can be great and some obviously terrible, generally the less popular the less reviews you find.
Michelin for instance is a VERY popular tire brand, however they are way too hard of a tire for me and how I drive.
Toyo is also a very popular brand, I tried some and that was the scariest tire I have ever driven on.
only advice I can really give you is pick a tire that you feel will suit your driving style and driving environment (find a happy medium).
once you pick a tire, then shop around for the best price, on sale, manufacture rebate etc.
then once you have your best online price, call around to some local shops and ask them what the "cash" price is, presuming you are in a position to pay cash
the tire shop down the road from me will match or beat anyones price and they are just a single no name blo jo shop plus free rotations and repairs included.
if I pay cash there is no tax
blackelky
I have decent experience with good year as of late. Best prices on goodyear are at walmart.com but i wouldn't get them installed there just ship to store. Mainly went to simple tire because of road hazard warranty....I'm A SUCKER FOR WARRANTIES.
Big Mama
Virginia
Just tossing in a question. What is it about abrupt lane changes or other maneuvers that has you worried? What ruled out lowering your center of gravity? Tons of great advice here from some very experienced folks.
M
Marky Dissod
Well, it's one thing to know that it's a Tahoe Z71, not a Tahoe PPV / Tahoe Limited, and certainly not a Caprice 9C1 / PPV ... on paper.
It's quite another to drive this truck, and kinaesthetically notice its reluctance to assertive lane changes & 'threading needles' in traffic compared to my old Caprices.
But there's more to it than the extra 1500lb and the ride height.
Already mentioned that I'm interested in UPGRADING, not merely maintaining / replacing the following:
#1: Jounce cushions have disintegrated ... if at all possible I'd like to find upgrades
#2: Bilstein 5100 seems like an upgrade over the 4600, which is exactly how I like it
#3: Hellwig or Nolathane swaybars ... unless I find another trusted respected brand of kit.
The day I test drove the Z71, it had snowed A LOT, which demonstrated the advantages of the Z71's higher center of gravity.
Before I lower it - which seems somehow easier to get wrong than #1 #2 & #3 above - I want to try those upgrades first.
For whatever it's worth, I already lowered it a lil bit - see my sig.
Surprisingly, ride quality didn't get any worse, except for the occasionally horrible road.
Long story short, I'm not yet ready to lower it; that needs (for me at least) MORE research.
Escalade2007
