2008 GMC YUKON HYBRID Transmission/from AZ
MARDIV1969
I have 2008 GMC 4x4 Yukon hybrid- bad transmission. The dealer informed they discontinued that transmission or parts for it. Having a hard time finding some one that would rebuild it, any body know where I can get parts for it, or get it rebuilt. Thx.
nonickatall
Germany
Wrong Section in the forum and wouldn't it be helpfull to write where you are from? Because most sense make a local transmission shop to fix that. I guess you won't remove the unit and send it throught the country...
M
MARDIV1969
Thank you,
Thank you, I'm in AZ.
T3xasR3dRum
They do not sell any parts to rebuild these transmissions. I recently was able to find a used one an are about to remove and replace the damaged one. You have two options find a
used one or spend 11,500 Chevy will build you one takes about a year
rockola1971
Indiana (formerly IL)
car-parts.com
NickTransmissions
Sin City
The transmission bench
Cobra transmission has parts for these listed on their website and Transsatar may have some parts as well. What drives the cost/scarcity way up are the hydro-electric motors as they are very expensive ($1500+) to replace if bad.
I havent worked on one of these units (yet) but have done a bit of research on them as every once in a great while someone will call inquiring about overhauling one of them...seem like interesting transmissions...
j91z28d1
I still might pick up a spare to have around if one pops up locally. there's a 2wd one local on market place now that I need to research if it's swappable. just something I'd stash in a corner it I ever needed it. just struggling with motivation.
but if mine went out and you were up for rebuilding one. I think I'd bolt it to a pallet and ship it your way haha.
BG1988
most likely the AUX pump, controller went out on it that would be a good place to start with
or it doesn't move at all?
j91z28d1
@NickTransmissions
would you happen to know of any way I can find out if a 2wd one of these trannys can be converted into a 4wd to bolt the T case on it? I've looked all over online and found nothing. I'd buy a manual if I could find one.
I keep seeing posts about 6L80s being quoted $7k to rebuild these days, there's a 2wd hybrid one local for 600$. I have no way of testing it, but he says it came from a running truck. feels like it can't hurt to have in a corner if I ever need it.
NickTransmissions
Sin City
@NickTransmissions
Unfortunately, I don't at the moment (not for 100% certain, anyway) but will be going to my transmission parts supplier this afternoon so will ask to see what 2ML70 stuff they have and level of effort to convert (though I suspect is just an extension housing assembly swap since the output shaft and rear gear train are all nested w/in that extension housing kinda like a Chrysler 42-48RE).
Will post back later this evening with what info Im able to gather and we can go from there.
NickTransmissions
Sin City
@j91z28d1 - no luck at the parts place. The only thing they sell is a filter and gasket for the hybrid trans. They haven't seen a core come through in about 5 years so couldnt tell me what all had to be done for the conversion.
j91z28d1
thanks for asking.. I'm not surprised at all that they haven't seen one in a while. low production numbers and I believe most out live the battery and the afm stuff leading up ending up in junk yards before the trannys gives up. I'm just hoping to keep mine for a very long time. I have seen a few posts here and there that did sound like a motor or something went bad and not just a bad diagnostic blaming the tranny for failing undersized prius batterys in a 6k lbs truck haha.
I get the feeling if this one ever goes, I might have to try my hand at rebuilding haha.
NickTransmissions
Sin City
You're welcome, man.
It will make for an interesting rebuild project.
BG1988
Another issue is the X175 connector getting backed out pins OR chafed wires near the parking brake area
Causing a No start or NO shift condition
See TSB
Halomez
I've seen them on LKQ from time to time.
Knagawa350
Portland Oregon
Anyone able to find a manual for the 2ML70? I’m attempting to rebuild the two clutches that failed. (Clutch 4 and clutch 1-3) hybrid ones are fine for now. I found an article online showing both are the same assembly behind the first electric motor coming back from the bell housing. I sourced all the parts and had GM verify part numbers
Jerald Burley
I am in the process with trying to rebuild my 2008 Tahoe Hybrid transmission because the transmission shops in my area (Alaska) aren't familiar with the transmission and the dealership states there aren't any 4x4 transmissions available in the US. The website I found for parts is smcautoparts.com. if you do find a guide please let me know, I haven't been able to find anything.
Hodmjstone
