Budgeting for a paint job
91RS
GA
You can’t do a “scuff n spray” over failed paint. You can see the failed paint through the new paint, I’ve seen it done. You have to sand it down to bare metal, confirmed by every body shop that I got quotes from (and half said they still wouldn’t warranty it even sanding it down to bare metal). The straight costs of materials is probably 1/8th of the cost of a good paint job.
If you want to go cheap, get the hood and roof wrapped. That’s what the previous owner of my truck did and it actually didn’t look too bad. I think I was quoted $600 to do a fresh wrap on it.
JPS0284
I know. And it doesn’t last. That sheeetz irritates me….. :rolleyes:
That’s unfortunate sorry to hear you had a bad experience. There’s so many factors that determine how well the panel will come out. Im merely a hobbyist diy painter with a couple nice guns and a decent compressor setup. My childhood best friends Dads famous quote for us around the shop: “you guys only know enough to be dangerous.”
91RS
GA
Quality of the paint doesn’t matter. It’s the quality of the prep work that matters. Using the worst paint on the best prep work will look better and last longer than the best paint on the worst prep work.
100%! All about the prep.
adventurenali92
Big Bear Lake, ca
“You guys only know enough to be dangerous”… sounds like me :D I’d like to get where you’re at though as a hobby IDY painter. I’m gonna start researching what I need to make that happen.
You can get a decent diy spray gun from HF. Make sure you get at least a 20 gal compressor to use with the gun. Imo you don't want to get anything less then that.
JPS0284
Okay, but why? They use quality paint... of course it will not be as good as a $8k or $10k or #20k paint job but I would expect that.
Price is
What Tony said, in most cases your gun pressure will be in the 12-18psi range. if you have the room and 220v access I’d go with a 60gal with a HF big dryer and the mini regulator/dryer/desiccant dryer. I started with a set of H guns, they’ll lay down some nice work once you get them dialed in. I still use my HF guns mostly for primer/sealer I eventually worked up to a devilbiss tekna prolite which is mainly used for base/clear.
pwtr02ss
Tennessee
I haven't read the full thread but I'd say $8-10k. You may get quotes to do it cheaper but you get what you pay for. Since the paint is aged and delaminating more easily, it would need to be stripped to at least the primer for proper adhesion.
Have you considered a full wrap?
Geotrash
Geotrash
Dave
Richmond, VA
Thanks, Tyler. Yes, I would be open to that and have even been playing around with some designs. Any idea what that might run?
pwtr02ss
Tennessee
Around here, depending on door jambs and things, I think it starts at like $2k and goes up from there.
They make some really nice vinyl these days and if bodywork is still nice on it, I'd go that route before I spent the money on a full repaint. Quality work is hard to come by these days and with a wrap, they can peel it off and start over if they mess it up.
BadDaddy2003
